Question about Tablets & eReaders
Hannspree manual How to create and name different album's in photo gallery
How do I contact a live person to ask questions about my 4th gen iPad?
I am a live person and an iPad, iPhone expert. :>)
Your iPad contains a main album called 'All Photos', there are other Sub Albums, Favourites, People Places, Videos, Selfies, Panoramas, Bursts, Screenshots, Recently Deleted.
All images go into 'All Photos, they are sorted to make it easier for you to find images, but linking to them via the Sub-Albums. If you Delete from any of the Sub Albums, it also gets deleted from All Photos. If you delete from All Photos, it will go from the Sub Album.
They are not 'DUPLICATED', but linked.
Apr 06, 2017 | Apple iPad Tablets & eReaders
How do u access sd card to down load photos - galleries/M729B?
Insert in slot marked for SD... go to my computer if it's windows machine... select drives... look for drive that has d or e next to it... double click and see if your pictures are there...if so right click on the pic you wand and select save to... and pick a spot on your computer you want em...ie picture... photo album...
Dec 02, 2014 | Tablets & eReaders
How to delete or remove all photos stored in samsung galaxy tablet 3 gallery?
Although I do not have a Galaxy Tablet 3, I own a Samsung Galaxy S3 phone and I believe both might use the same technique.
There are two ways to erase the photos from the gallery. I generally use the first one, using a computer although you may prefer the second one that works directly in the tablet.
In general, when you connect an Android device that has a camera to a computer, it will display in the Windows Explorer an Icon with the name of the device, if Windows has the right drivers for your device installed. At the same time, an icon of a USB connection will be shown in the device's screen top bar.
If you click on your device's icon at the computer, you may find one or two folders (in general, "Card" and "Phone" in cell phones" and "Card" and "Tablet" for tablets). The "Card" folder appears if you have an SD card inserted in your device. Depending on where you set up your tablet to store the photos, inside those two folder you will find another folder called DCIM (that stands for Digital Camera IMages). Check on both to locate where your photos are. Then, select the ones you want to erase or select them all pressing CTRL + A and then press DELETE on your keyboard.
The other way is acting on your tablet. Touch the GALLERY icon to open the Gallery app. If you have more than one folder in your gallery, touch on the folder you want to erase the photos, to select it. If you have only your Camera folder, touch and keep you finger touching any of the photos for around two seconds. The photo will be selected with a green mark and a rectangle will appear at the top, close to the Gallery icon, indicating "1 selected". Touch this rectangle and the option to either "Select all" or "Unselect all" will appear. Selecting all photos will turn them all marked. Then, touch the "Trash can" (delete) icon and you will be asked if you want to delete all pictures. Touch OK and they are all gone! See images 1 and 2 attached to this note.
Hope you may find this information helpful!
Regards,
Miguel L. Martins
Jun 07, 2014 | Samsung Galaxy Tab Tablet PC
Ipad 4 user manual
Select picture. Open picture. Bottom left, square and up arrow icon. Press icon, press copy. Bottom of screen, press album, and press plus icon at top to add album, and or go into album and paste picture like you copied.
Apr 14, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Tablet instructions manual
How do I create albums for photos from the gallery for a Thomson platium tablet
chhers,
jill
Jan 08, 2014 | shop-fun JXD S6600 7 inch Android 4.0 All...
How do I delete photos off the camera roll without deleteing them off the album
There are two methods to delete photos from iPad Camera Roll:
1. Import the Camera Roll to your computer, choosing to delete photos after import.
2. Delete photos from your iPad manually. Open the Photos application, open the Camera Roll, tap the Action button, tap each photo to select it, and tap the Delete button.
Note: For photos you want to save for later, import them to your computer before deleting them from the Camera Roll.
Aug 23, 2012 | Tablets & eReaders
How can I delete a picture in my Gallery Album
right click on the photo select delete
Aug 04, 2012 | Acer Iconia Tab A200
How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
Jun 25, 2012 | Apple iPad (16 GB) WiFi Tablet PC
How do I transfer my photos from my documents on my PC to my IPAD
  1. Plug the iPad into your computer to sync it.
  2. When the iPad management screen appears, click the "Photos" tab at the top.
  3. Check the "Sync Photos" box at the top.
  4. From the drop-down menu next to that, select the program or folder that contains your photo library.
  5. Depending on what program you use, you'll have different options. These may include syncing individual galleries or your entire photo album.
  6. If you're syncing a folder of images, you can navigate through your hard drive to find the correct folder and then sync that entire folder or just select subfolders in it.
  7. Once all your settings are correct, click the "Apply" button at the bottom right corner of the iTunes window to sync again and add photos to your iPad.
Dec 29, 2010 | Apple iPad 64 GB 3G Tablet PC
Tablets & eReaders Logo
16 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
