Question about Toshiba Satellite Computers & Internet
How to replace toshiba satellite keyboard - Satellite Toshiba Computers & Internet
    Master:
  • Toshiba Master
  • 752 Answers
Trying searching the internet with "replace keyboard toshiba satellite" (skip over the links about those for sale), there are a few relevant ones e.g.,
http://www.ehow.com/how_5942786_replace-keyboard-toshiba-satellite.html
or
http://www.instructables.com/id/Replace-a-Toshiba-Satellite-laptop-keyboard/
You will find videos as well, which might be of more use, e.g.,
http://www.youtube.com/watch?v=F62RbnA06Fo
or
http://www.youtube.com/watch?v=HsuH8EzPhPY
If you are after the exact procedure for a particular model, try searching on the model, either on the internet or on youtube, or try the service manual from the Toshiba website, if one is available.
5.May.2014
Posted on May 05, 2014
Pyrhyc
  • 2028 Answers
SOURCE: Toshiba Satellite A135 Keyboard replacement.
Keyboards remove in two different ways on just about all laptops. 1- There are screws on the bottom that hold it. 2- The screws are located under the power button strip at the top of the keyboard. Here's a couple of links that you may find a breakdown diagram for your machine.
http://repair4laptop.org/notebook.html
http://www.eserviceinfo.com/service_manual/datasheets_d_600.html
Posted on Jul 01, 2008
Binary Bob
  • 91 Answers
SOURCE: Toshiba Satellite A135-S2266 Keyboard Replacement
I hope that this will help. Do not be alarmed by the fact the link points to the "Memory Module Installation". In order to get to the memory on your Toshiba, you will have to remove the keyboard.
There lies your answer.
Here is the link: http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1504541xml&sliceId=&dialogID=60550899&stateId=1%200%2060552663
Binary Bob
Posted on Nov 27, 2008
joecoolvette
  • 5660 Answers
SOURCE: Replace keyboard on Toshiba Satellite 1410-s173
First remove the AC adapter (Charger) if plugged in. Then remove the battery.
Next step is removing the Keypad Securing Strip. This is a plastic cover right Above the keypad, and below the LCD screen. Looking at it, you'll notice on the Left and Right sides of it, that it has a U-shape.
This U-shape covers the LCD screen hinges.
Take a small flat tip jewelers screwdriver, and come from the right side of this plastic strip. You will see a thin parting line, where this plastic strip meets the laptop body. Your flat tip goes in this parting line. You have to use finesse. It's doubtful you'll break the plastic strip, as it's REAL tough! But if you slip, you could scratch the plastic. (Actually, it's pretty hard to scratch that plastic! Just thought I would caution you. The plastic strip is made of a spaceage plastic. Pretty tough stuff!)
The plastic strip has tabs around the edges, every so often. These
plastic tabs snap into place, and hold the Keypad Securing Strip on. When you begin, it's a little tough to get that flat tip down in there. (Remember ->Jewelers screwdriver!)
Plus, you may be at one of the points that there is a tab. Usually there is a 'dimpled' flat place, that looks like a flat tip should go there.
With the flat tip jewelers screwdriver inserted a little, ease back on the screwdriver, and lift the plastic strip up.
It will look like it's bending. If you have another flat tip Jewelers screwdriver, or a small butterknife, you can insert it, and hold this part up. Then take the other flat tip, move over a little, and start lifting up.
Once this Keypad Securing Strip starts coming up, it will come to one of those tabs, and the tab will come up and out. You'll hear a POP, and think you broke it! You didn't.
Go along the edge, and keep popping this strip up. Use caution, as to how far you insert that flat tip screwdriver!
There are tiny little wires under there, and you don't want to pinch one, or tear it loose. Keep the flat tip, about a half a fingernail length in, and you won't.
Once you get towards the other side enough, the strip will let loose, and come up.
Without disconnecting the wires, see if you can lay the strip towards the back, and lay it out of the way. Towards the LCD screen. You are trying to get to the screws, that secure the keypad. They will be in a metal strip for the keypad, and towards the LCD screen.
I can't remember at this point if there are two, three, or four screws. You'll be able to see, and you'll know.
(Use Caution! You can easily drop these screws! They might go right into the body of the laptop. You MAY be lucky enough, to pick the laptop up, turn it over, and gently shake the laptop, to have them fall on the table. You MAY not be so lucky, and have to disassemble the entire laptop, to get to them!)
IF, the Keypad Securing Strip will not lay out of the way, so that you can get to the keypad screws, you'll have to remove it.
It isn't tough, but it looks daunting the first time.
You will see small White connectors in the middle of the cables.
Two wire cables, if memory serves. These connectors are small White rectangular blocks. There is a Female and a Male. You just take your fingernails, and ease the connectors apart.
Don't worry about how they go back together. They are different sizes. You just match up the size.
Now with the keypad securing screws removed, ease the keypad forward a little, and bring the front of it up to a tilted position. (Towards the LCD screen is the front of the keypad) You don't want to bring it straight up, as there is a flat ribbon cable you need to disconnect. The flat ribbon cable attaches at the back of the keypad. (Towards you) It has a White connector.
This connector is different, from the ones you have disconnected already. The connector itself has a locking 'bar'.
This thin rectangular piece of plastic, goes across the length of the connector.
It is positioned at the front of the connector. It comes forward, towards the flat ribbon cable end, that is connected to the keypad.
It slides. It only slides so far, then stops. It is at this point, that you remove the flat ribbon cable itself. The one towards the keypad. There will be No connector on that flat ribbon cable. It will be just the ribbon cable itself.
When you reattach it, you just slide the flat ribbon cable back into the White connector. Then you ease that locking bar back into position. The position that it started from.
Now reverse your steps.
Posted on Apr 18, 2009
SOURCE: toshiba satellite a215-s5837 keyboard does not work
Yes, replace entire thing. It's really a membrane key anyway. NO contact to clean..
Posted on Feb 10, 2010
  • 6 Answers
SOURCE: How to remove and replace the keyboard on a Toshiba notebook
Manual at Here (http://uk.computers.toshiba-europe.com/innovation/download_manuals.jsp?service=UK)
it should tell you in there, you may need a positive screw driver as well
Posted on Feb 12, 2010
How to replace keyboard on Toshiba satellite c55t-b5230 laptop
Toshiba Keyboard Replacement - Satellite Laptop - YouTube
? 5:19
Mar 6, 2012 - Uploaded by Jennies Garage How to remove and install a keyboard on a Toshiba Satellitelaptop computer. ... This video should help If I ever think ofreplacing the keyboard.
Sep 17, 2015 | Computers & Internet
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
How to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
Apr 15, 2012 | Toshiba Satellite L655-S5160 Laptop PC...
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
I have a Toshiba Laptop Satellite M505-S4940. The
the only way to get rid of this is to replace your built in keyboard....!
May 12, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
Toshiba satellite a215-s5837 keyboard does not work
Feb 10, 2010 | Toshiba Satellite A215-S5837 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
