Question about Murray Garden
Murray Model 42910 X92A OPERATOR'S MANUAL
I NEED DOWN-LOADABLE OPERATOR'S MANUAL FOR A MURRY LAWN TRACTOR MOD.#42910 X92A SER#95269-131900
    Loyalty:
    Visited the website for 30 consecutive days.
  • Murray Master
  • 1,167 Answers
Check with SearsPartsDirect.com or Mc Gyvers Workshop
Posted on Jan 17, 2018
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
  • 69 Answers
SOURCE: looking for owners manual sears 15.5hp craftsman
Look here...
http://www.managemyhome.com/mmh/prod...Display.action
Posted on May 18, 2009
SOURCE: Murray Lawn Tractor won't go up hill
Your drive belt is worn/slipping
Posted on May 31, 2009
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
  • 35 Answers
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
Posted on May 09, 2010
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
I am seeking a service manual for a Murray ride on mower Model 405600X50B
Find a customer service number for Murry. Most likely they will
need model and Serial number. Probably will send you a replacement if your "nice about it".
Feb 27, 2015 | Murray Garden
Flow of belt between two small pulleys on a murry 425303x92
a4e1b0f6-5618-4d4f-bf75-6554491a4723.gifmaybe this can help.. NOTE: unsure if it is the exact same model as yours.
Jun 17, 2014 | Murray 46 Primary Lawn Mower Blade Belt...
Primary belt motion belt diagram for a murry 46 inch cut 2006 model
just did another murry today there is a sticker of the belt routing on the bottom of the foot rest
May 28, 2012 | Murray 46 Primary Lawn Mower Blade Belt...
I have a murry tractor and i need to know the weight
In general, the Murray tractors should weigh between 275-375 lbs.
Nov 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Model 40601B riding lawn mower-need tension pulley spring
Your owner's manual has a parts breakdown with all parts listed. Find the part # and order from local Sears store. No manual? Try the Murray website (www.Murray.com) and download the manual for model 425001x8D lawn tractor. Good luck!
Sep 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can't find model number
there should be a data plate somewhere on the tractor with model and ser #. Usually it is under the seat. The motor numbers are usually stamped on the engine cover with model type and code.
Aug 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need a wiring diagram for a Murry Rider, Model # 30575X8A.
Go to this web sight and enter your model number of your Murray.
http://www.murray.com/manuals/
Jul 17, 2009 | Mtd Garden
I Have a Lawn General Riding Tractor, I think it's made my Murray. The drive belt keeps falling off. It is model #42504x71a. Ser. # 7386702081f00626. The belt is not real old. A service center says that...
Hi, service manual and parts can be found on amazon, here:
manual: Amazon com lawn general riding mower manual
parts: Amazon com lawn general riding mower parts
after reading manual you can be able to detect your problem and see if you need new part or just small fix. I hope this helped you. Have a nice day
Jun 04, 2009 | Garden
Garden Logo
113 people viewed this question
Top Murray Garden Experts
Dennis Key
Dennis Key
Lawrence Oravetz
Are you a Murray Garden Expert? Answer questions, earn points and help others
