Question about Gaggia Coffee Makers & Espresso Machines
Gaggia MDF Coffee grinder stopped working - Gaggia Coffee Makers & Espresso Machines
SOURCE: Grinder spins but won't grind coffee
You have fill a water in your coffee grin
Posted on Jul 17, 2007
Buffalo12980
  • 625 Answers
SOURCE: Gaggia Titaminu
check to make sure the blades are secured to the motor shaft. some have a set screw, some are positioned over a pin in the motor shaft.
Posted on Sep 11, 2007
  • 833 Answers
SOURCE: Broken Handle on Coffee Grinder
Nice unit! Replace the part. Try www.smallappliance.com.
If you want to try to glue it first, get a product from 3 M. I think they call it super strength glue. Scrape off all traces of whatever you used before. Follow the instructions exactly.
Posted on Dec 03, 2007
  • 2039 Answers
SOURCE: Coffee not strong enough
our waste coffee is it consistant like stay in 1 round piece or loose lock at it if it lock like it was fine grind i suspect that our machine dont grind fine enough our coffee should have that lovely brownish cream on top maybe grinder need ajustment it wasnt done properly at the compagny and you said you adjusted the dial in the grinder but what about the quatity of coffee look in our manuel fine grounded coffee good quatity of coffee our suppose to get that perfect expresso i think ajust our dial for quatity of coffee thanks for using fixya pierre
Posted on Feb 09, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart grinder-brewer coffee maker
Use the bursh that came supplied with the coffeemaker to clean around the exterior of the motor area, underneath the grind basket. Make sure the chute is clean as well.
-Tha Mp3 doctor
Posted on Jan 09, 2009
I just disassembled and cleaned my Gaggia coffee grinder. When I turned it on to calibrate the burr plates it made a short grinding sound then stopped and now won't turn on
Take it apart again and check all the connections and switches, security shut-offs, and THE THERMAL SWITCH. A very small and cheap electronic device that takes and overload and will shut your system down, whatever it is. Very easy and quick to replace.
Nov 25, 2014 | Gaggia MDF Electric Burr Grinder
Need operating & maintenance manual for brevetti gaggia mdf burr grinder.
Hello, your instruction manual can be found on this link by clicking or copy and pasteing it to your browser http://www.gaggia.com/dam/bo/allegati/files/31_mdf.pdf if you are unable to obtain these instructions by copy and pasteing to your browser please message me back and I will provide my email so that I may send you them directly.
Thank you
Rick
Nov 08, 2011 | Gaggia MDF Electric Burr Grinder
I have a Gaggia burr grinder, Brevetti Gaggia SA Model MDF, s/n 7262. The handle that you flick back and forth to let the grinds come out broke off inside the unit.fixable? 707=837-8916 Thanks Anne
Look inside the grinder, The lever is attach to a SPRING .
May be the lever is disconnected (unhooked) from the spring.
AND YES IS FIXABLE.
It cost you about $15-$30 for the parts.
Jan 15, 2011 | Gaggia MDF Electric Burr Grinder
How do you change the grind on a gaggia coffee grinder?
if it is everything in order you change the grind buy rolling the plastic container of coffee beans(container commands to upper burr holder. If it doesn't go easy than disassemble container and unscrew the upper burr holder, carefully when it comes out, you have some pins and springs from below. do not loose or displace them.
Jan 03, 2011 | Gaggia MDF Electric Burr Grinder
How do you adjust the size of grind with a gaggia grinder
The is a little lever you push up by the bean hopper. Then rotate the bean hopper to change the grind.
Apr 20, 2010 | Gaggia MDF Electric Burr Grinder
How can I clean my Gaggia burr coffee grinder?
For parts you can see, use an artists paintbrush. If you want to clean the internals, grind some panko breadcrumbs or raw rice grains, then run some coffee through it a few times before using.
Dec 10, 2009 | Gaggia MDF Electric Burr Grinder
Can't disasseble burr set
take an oil filter remoover for cars(the model with 3 legs and gears will do better job). 2 man required one holding grinder other one start turning left and right the upper holder(during turning hold down the brake pin.) it is bit boring and job wich requires patience. but i think you will manage it
here is the diagram:
http://www.partsguru.com/images/Img844.jpg
Jul 12, 2008 | Gaggia MDF Coffee Grinder
MDF very coarse grind
Several possibilities loom:
1. Same burrs for 25 years? don't be cheap replace them!
2. Dirt in the threads of the burr carrier, or the threads that recieve it?
Let us know what works
Dec 18, 2007 | Gaggia MDF Electric Burr Grinder
Nov 24, 2007 | Gaggia MDF Coffee Grinder
Coffee Makers & Espresso Machines Logo
23 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
