Question about LG RC897T DVD Recorder/VCR Combo
KEEPS EJECTING DVD'S
WHEN UNIT IS POWERED UP IT STARTS TO EJECT DVD TRAY, THEN STOPS WITH TRAY OPEN.
2 Suggested Answers
ric2k06850
  • 72 Answers
SOURCE: I have a LG DR389
try to buy a disc cleaner it might be dirty and reinsert the same DVD. Hope this info help you resolve your problem
Posted on Jun 07, 2011
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
Tip
My 2910 player has similar issue. The tray gets stuck on eject. Started with not...
1)just open the player
2)remove the rubber belt connecting the dc motor
3)you can open the disc tray now
4)if there are any dust particles or obstacles in the door way just clear them up by using the cloth(dry cloth preferred)
5)if you have any greasy material like vaseline,oil,etc then just put that in the door for easy movement of the disc tray
6)if needed change the rubber belt which is connecting the dc motor
7) just reconnect the rubber belt again and then just fit all screws that s all
what s more your player s disc tray will start ejecting like the previous how you were using..
any doubts you can reply me
i am always here to assist you
thank you
bye
on Jan 06, 2009 | Samsung DVD-V4600 DVD Player/VCR
Sony Ns575p wont eject DVD
Someone is going to have to open the unit to look to see if mechanism is jammed or out of alignment or if the disc is not in the proper position---either mechanism or a jam is most common here.
Oct 21, 2012 | Sony DVP-NS575P DVD Player
My dell studio 1535 keeps ejecting any disk i try to insert. When I boot up the system the drive sounds like its ejecting about 4 times.
It is likely you will have to replace it. When you boot up tap f12 while the bios is loading and select diagnostics to see if you can get a error from those tests.
Aug 02, 2011 | Dell Studio 15 Laptop
I put in a dvd into the dvd player, and went to eject it. I pressed the eject button and a "locked" caption came up on the screen. I dont have the owners manual and I cant figure out how to...
You may have enabled the child lock feature, try pressing the Return, Enter and Power buttons together to toggle the lock off. If this is disabled and you still can't open the tray, turn off the unit and unplug it. After 30 seconds or so, plug the unit back into the electrical outlet. Attempt to open the tray. If this does not solve the problem, try pressing Power + Stop + Eject buttons together. Also try pressing Disc1 + Stop + Eject simultaneously (if a disc1 button is on the remote or player).
If the error message is t - L C K or persists after trying all of the above steps, then you need the unit serviced.
The manual is available at the Sony support site: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPSR200PB .
I hope this helps.
Apr 16, 2011 | Sony DVP-SR200P DVD Player
My cd rom tray will not eject and the light is
have you manually tried to eject the disc tray? There's a little hole on there somewhere, stick an unbent paperclip or safety pin in it and push until the tray starts to come out, then pull the tray out with your fingers.
Once you've done that, push the button to allow the tray to automatically retract.
Jul 22, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
I got a cd stuck in the cd/dvd drive for my gateway laptop- i dont know the model. tried to hit eject button and ejecting through computor and it will not open. what do i do?
All CDs & DVDs have a tiny hole on the drive tray.
Get a paper clip, straighten the paper clip and insert it into this hole and push the paper clip in gently, the tray will release and pop out, then you can remove your disc.
You can do this without the laptop being powered up or powered down.
Feb 21, 2009 | Gateway M305CRV Notebook
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
Sony DVD RW DRU-820A
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
Mike @ compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
LG RC897T DVD Recorder/VCR Combo Logo
Computer Repairing
Computer Repairing
