Question about Gateway Computers & Internet
Flash drive wont show up in explorer or disk management
I have a pny 16gb flash drive which worked just the other day but now when i insert it into a usb port on my gateway T6815 laptop it will make the noise that a usb device has been plugged in, but it wont show up in either windows explorer OR disk management.....when i unplug the device it makes the sound that the device has been removed, but still no matter which of the three ports i plug in to it isnt recognized and it isnt showing up in device manager as either a problem device or an unknown device
sandrew
  • 2961 Answers
SOURCE: USB ports not working Acer Aspire laptop
Two solutions would be to either restore your pc to before the problem started,using system restore on accesories menu, or use the recovery cd or the recovery folder Acer laptops usually have on the 'D' drive and re-install usb controllers and drivers.
Posted on Nov 24, 2006
djnick989
  • 1067 Answers
SOURCE: usb ports do not recognize flash drives
regisrty key maby u could try repairing your windows back it all up redo it maby sum spyware or sumthing if not bad board not powering good engh to usb
Posted on Jan 22, 2008
falseadress
  • 45 Answers
SOURCE: Aspire 3610 USB ports
I think you might have a loose cononection for the data ports. Try putting a little bit of force on the usb device. Up, down left right. NOT ALOT. If it starts working when force is used, i tihnk you should try to take it apart and resolder the connections. If it dosen't work, uninstalling the driver and installing.
Posted on Jun 01, 2008
mediarich
  • 188 Answers
SOURCE: Usb ports do not work
Try going into device manager and deleting the USB devices, Reboot and let Windows try and reinstall the drivers. If that doesn't fix your problem post that it didn't work and I'll get another message.
Posted on Dec 16, 2008
haayz
  • 197 Answers
SOURCE: usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Posted on Jun 02, 2009
How do i know/change my new PNY 16GB USB flash drive to "comply with the USB Class Specification (USB MSC) and supports formats of FAT32 and FAT16" per my car infotainment system requirements? i am trying...
You have to format the drive to the correct type before transferring your music onto it. Not sure whether you're using windows or Mac. In windows go into file explorer, right click the usb drive and select format. This will show you a section of formats including FAT32.
Feb 22, 2015 | PNY Electronics - Others
WHY WONT MY 16GB PNY FLASHDRIVE WORK WHEN I DOWNLOAD A MOVIE ONTO IT?
Perhaps it has not been prepped, eg: not formated to use. Format it with fat32 file system using formatting software from the manufacturer. Also, make sure the movie file does not exceed 16 GB.
Apr 30, 2014 | PNY Attach? 16GB USB 2.0 Flash Drive
My computer thinks my pny 32GB USB 2.0 flash drive is a disk
All pen and SD cards show up as removable hard drives. Removable or not they can be treated the same. You can format again just by right clicking on it, or use diskmgmt.msc to fully manage via the MS management console.
It's basically doing the same as you did from the cmd prompt.
If you asking to restore files, then you require a 3rd party software. There is Recuva (free), Wondershare, and Stellar. They all do the same thing.
Dec 11, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
Is the pny 16gb flash drive fat32 formatted?
click start click on my computer you should see your memory card
right click then select format
another way is to control panel administrive tools computer management disk management right click on your memory card or it might be listed as a mass storage device
select format
you will see what its formatted in
hope this helps
Jul 14, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
My pen drive is detected but when clicked to open it is showing me to insert disk into the rive
You may be able to access it through Disk Manager ( right click on my computer and manage/disk management), if you can , try to change the drive letter (right click option)
A drive letter conflict is quite common
Aug 02, 2010 | PNY Electronics - Others
I just bought a pny 16gb usb 2.o drive to download pictures from computer onto the pny and it wont do anything. i have a xp
Is your memory card is recognize by windows or you didn't see it on windows explorer!
if you dont see it on explorer it could be solve by a service pack!
and if you see it on windows explorer but can't copy anything the card may be locked with the little tab on the side of the card!!
Jan 04, 2010 | PNY 2GB microSD Memory Card
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
8gb pny pendrive not working
Try to connect it to another usb . If it still does not see it do check disk with fix errors. I had such a problem many times and usually check disk helps.
Apr 18, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Pny 16gb attachi flash drive reccognized by my computer but says insert disk into drive when I left click it
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 14, 2009 | PNY Attach? 16GB USB 2.0 Flash Drive
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
