Question about Barbeques Galore Grilling
Need to change my orfices in barbeque for natural gas orfices are the natural gas orfices all the same
burzerko
  • 254 Answers
SOURCE: Regarding gas Barbeque and charcoal Barbeque
It depends on your preferance
Charcoal most say it gives what your cooking better flavor but the disadvantage is waiting for the coals to get hot and longer cooking time due to less heat.
Gas quick cooking time, quick warmup time the disadvantages scrafice some of the flavor, unless you buy a gas grill set up to smoke it is almost impossible to use a conventional gas grill for smoking, and also you have to have enough gas to cook completly or have a second tank in case you run out.
Hope this helps Ya
please rate me
Posted on Jul 20, 2008
ldaala
  • 65 Answers
SOURCE: How do I change a natural gas barbeque burner
most of the burners are just a slip joint so all u would have to do it pull or take a hammer to it and it should remove pretty easy after that good luck
Posted on May 26, 2009
  • 60 Answers
SOURCE: orfices for the grand turbo double side burner
bbq galore call 214-696-0030 even if your not in dallas they can send them to you
Posted on Aug 23, 2009
  • 512 Answers
SOURCE: How to change a propane barbeque to natural gas
Most grill makers do not offer a kit to convert. Look in your manual and call manu and see if they do. My answer would be they do not have a conversion kit. You have to buy a grill that is natural gas.
Posted on Feb 08, 2010
gcken
  • 140 Answers
SOURCE: burner will not stay lit
try to replace the regulator on the grill
Posted on Apr 04, 2010
Wanting to change propane stove to natural gas,need parts to do that
Most ranges can be converted with the orfices being changed.Newer ranges have the orfices under the top.Older ranges can be convetrted by drilling the orfices larger.(propane orfices are smaller than natural gas.Sears can sell you a conversion kit if you know the model and serial #.Most Gas companies will convert it for a fee.
Mar 05, 2014 | Kitchen Ranges
Want to convert lp gas to natural gas laarslite llg250
not adviseable years ago they would sell you different orfices and change the gas valve setting but too much liability involved LP runs hotter so they had smaller orfices unsafe
Mar 21, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
I need to change the stove to operate on propane instead of natural gas.
You will need to conact a gas safe engineer who will change your gas jets from natural gas to LPG, then carry out various test to makesure your flueless appliance burns the gas safely and efficiently
Jul 11, 2011 | Hotpoint Kitchen Ranges
Convert back to natural gas
the burner orfices will have to be changed ans pressure reg / some have either /or reg / just turn lever to the fuel you are using . but always change the orfices to gas or lp . blk is lp copper nat gas .. you can probably do it with out the instructions it's very simple .. if the other set of orfice's are not in or on range then order them for your model . ..mm
Dec 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do i change from lp gas to natural gas on wall oven
First thing you will need to do is find out from the manufacturer of the oven if there is a conversion kit available and if the appliance is convertable. If there is then you can order the kit and follow the installation instructions. Also check the back of the oven for an envelope that may contain the gas orfice replacement heads to convert the appliance to natural gas. If you find the replacement orfice then you will need to remove the lp orfice from the burner and install the natural one. Then the appliance gas regulator will need to have the pressure adjusted lower for natural gas. There is usually a removable cap on top of the regulator on the oven. When you remove this cap there is usually a small metal ring that you can remove and flip over. It will say "nat" on one side and "lp" on the other. You will need to turn this ring over and re-insert so it displays "nat". This will change the gas pressure from 13 inches W.C. to 4 inches W.C. Some appliances only require the orfice change and no regulator adjustment but make sure that is the case with your oven because if you feed 13 inches W.C. pressure to a burner with a natural gas orfice...YOU WILL GET A HUGE BURNER FLAME AND MAY BURN/FLASH YOURSELF...So use extreme caution when converting a gas appliance. And if the oven has a pilot you will need to adjust the pilot pressure or change it's orfice if it has one. If it is electronic ignition no adjustment to that will be needed. Also unplug the electrical power the the unit while working on it.
Oct 11, 2009 | Ovens
Orfices for the grand turbo double side burner
Aug 22, 2009 | Barbeques Galore 38" Grand Turbo built-in...
Deep fryer from a restarant to change over to propane need orfices
I am looking at buying a pitco double deep fryer. It is natural gas, is it possible and at what cost to switch it over to propane. Model: F14S-CV - Serial: G99DC09212 Thanks Derek
Jul 19, 2009 | Pitco Frialator SG14 Deep Fryer
CHANGING AN ORFICE
This unit cannot be converted from gas type to gas type.
Feb 24, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Converting to gas
If it does not get hot enough when using natural gas then the small propane orfices must be sized larger for the equivalent BTU rating of propane. Conversion tables are online via Google
Jan 03, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
Grilling Logo
Top Barbeques Galore Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Barbeques Galore Grilling Expert? Answer questions, earn points and help others
