Question about Reddy R60A Utility Heater
Bad fan motor on lawn boy ph150 heater
Where can I get a new fan motor part number 154037 A?
2 Suggested Answers
tbugger
  • 232 Answers
SOURCE: my heater is not getting
Lawnboy? Man, that thing is old! Keep it running cause they don't make 'em that good anymore.
Check to see if the Ignition Device (transformer, spark box) is getting 110v. This box must have a good ground to the frame. If not, the unit will not produce a spark at the plug. If it does have a good ground, then the part must be replaced. The current replacement part is 102482-01
Posted on Nov 13, 2010
Bad boy mower
need to level deck
Aug 11, 2013 | Garden
My heater is not getting any fire at sparkplug torpeto heater buy lawn-boy model num ph150
Nov 13, 2010 | Reddy R60A Utility Heater
Heater does not work
Check heater fuse.
If fuse good - could be a failure of the blower fan motor or blower control switch.
If fuse bad - bad blower fan motor could have blown the fuse.
DO: check fuse, then blower motor.
Pricing: new blower motor: Duralast PM270 $43.99
new heater control switch: Duralast SW229 $46.99 (without
A/C).
I'd expect your blower resistor to be good - when they fail, the blower only will work on HIGH setting.
Oct 23, 2010 | 1993 Dodge Caravan
Need pamphlet for Briggs,Stratton Eastern Lawnmower 2007 Took lawnmower apart, cannot find book on how to put it back together.
You must have model numbers to get any real help. If you mean you took the motor apart, you could go to www.briggsandstratton.com/ and download a manual.
Find your model number on your motor and enter on web site.
Aug 10, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Just bought a 10 year old lawn boy 2 cyl mower from my neighbor. He had not used it for 5 yrs (heart problems). I put the 2 cyl ashless oil into the gas like the instructins said 32/1 mix. That turned out...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helps
May 20, 2010 | RTO Lawn Boy 6.75hp Mower
Heat/ac fan only blows on high
Check the heater control switch,,,,,and the number of wires at the heater motor....Some motors have more than one winding...in which case there will be three or more wires going into motor..there can be burnout in those windings and will require a new motor....check the plug which attaches to the motor....can be bad connection...or at the switch.....but if there is only two wires....then the heater switch uses resistors to slow down the different speeds...and direct connection for high speed....and the problem is definitely the switch...
Apr 27, 2010 | 1996 Lincoln Town Car
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
PH55 "lawn boy" porta- heater need parts
Lawn Boy sent me an 800 number for the company they sold the heater line to.
800-362-6951 portable heater parts. I have not called yet to find out if they will have qhat I need. Will call tomorrow, Tuesday.
Steve
Jan 25, 2009 | Reddy R60A Utility Heater
Reddy R60A Utility Heater Logo
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
