Onkyo receiver heating up in standby mode - Audio Players & Recorders
3 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Posted on Sep 15, 2007
  • 4234 Answers
SOURCE: receiver does not power on. standby not on either
The standby light should be on. If it is not, then check the main fuse. WIth the unit unplugged, remmove hte top cover and check the fuse by the line cord. If that is ok, then you will need to check the primary winding on the standby transformer. That transformer has a thermal fuse internally located and that sometimes gets blown due to a power surge. If you do not have the equipment to test this, get a detailed estimate from a local servicer. The standby transformer usually costs arounf $25 or so.
Dan
Posted on Apr 26, 2009
I Have The ONKYO TX-SR603X receiver ALL BY ITSELF I NEED HELP RESETTING IT
Hello, please see the procedure below to reset the receiver
Resetting the AV receiver to its factory defaults To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "CLEAR" will appear on the display and the AV receiver will enter Standby mode
Apr 26, 2017 | Onkyo Audio Players & Recorders
How to fix Onkyo TX SR 303 when it says phones engaged but no phones are not plugged in
Hello, I suggest a reset of the receiver. Please see the procedure below. Thank you, Onkyo USA.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1/VCR] button, press the [STANDBY/ON] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Feb 28, 2017 | Onkyo Audio Players & Recorders
Have noise on left back speaker channel of onkyo 606 blocking sound from movies etc
Hi Brendan, have you swapped the speaker from the left channel to the right one so that we can be sure that it is not the speaker? You can also try a hard reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at askOnkyo@us.onkyo.com, Thanks,JT
May 04, 2015 | Onkyo Audio Players & Recorders
Onkyo TX NR515 .. when in standby mode .. light is not coming on .. everything works fine .. i must have pressed something by mistake but cant work it out what ... on the display panel in standby mode...
If Zones are turned on or, if a mobile device connected to the Front Input is charging (MHL), the HYBRID STANDBY indicator won't light. See the TX NR515 owner's manual at http://filedepot.onkyousa.com/Files/own_manuals/TX-NR515_English.pdf for more info.
Feb 19, 2015 | Onkyo TX-NR515 AV Receiver
Can i shut off standby mode other than unplugging the unit?
No...fully disconnecting power requires unplugging it.
Dec 28, 2014 | Onkyo TX-SR875 Receiver
How to reset factory settings for onkyo tx-sv303pro without the remote
To reset the AV receiver to factory default ,turn it on and, while holding down the (VIDEO 1/VCR) button, press the (STANDBY/ON) button "Clear" will appear on the display and the AV receiver will enter Standby mode. :)
Jan 14, 2014 | Onkyo Audio Players & Recorders
I have SR 307 onkyo A/V receiver home theatre system. the remote control has stopped working. i checked with a local dealer and that the remote is okay and something has wrong in the receiver,
Did you check the remote with another Onkyo system at the dealer ??. If its OK try resetting the system. Remember you will loose all your stored presets ( FM and customized settings ) and the Amp will go back to factory settings.
While in standby mode hold down the DVD button and press the Standby/On button., the display will show Clear and the Receiver will go into standby mode. Turn it on and try the remote once again.
Jun 01, 2011 | Onkyo TX-SR307 A/V Receiver
I have an Onkyo TX-605AV receiver that will goturn off andgo into standby mode with loud sounds, when the volume is turned up usually over 60. I hooked the speaker wiresinto the banana clips for the...
over heating your amp with a problem and its going into the protect mode... better stop before it dies for good...$$$ to fix....speakers mismatch or wrong ohm rating for starters bad speaker, bad xover...
Dec 05, 2009 | Onkyo TX-SR605 Receiver
Receiver switches to standby without notice
This receiver is likely to be overheating or has a shorted speaker wire. If the unit is very warm when it shuts down then it is in need of some additional ventilation. Onkyo's tend to run hot so this is critical for proper operation. A speaker wire problem could also cause an issue when the unit detecs a no load situation.
Feb 25, 2009 | Onkyo TX-SR803 Receiver
"standby" on Onkyo TX-910
That sounds like an internal problem inside the unit
Jul 18, 2017 | Onkyo TX-910 Receiver
 Grubhead
Grubhead
