Question about HP Deskjet F340 All-In-One Printer
Paper jams each time I try to print. - HP Deskjet F340 All-In-One Printer
  • 390 Answers
SOURCE: paper jams/ printing blank
Thoroughly check for very small foreign objects in your printer, and check both behind in paper feeder area and inside the unit. Jams can be tiny pieces of paper than have gotten in or torn off paper fed in at slight angle but you may not have noticed. Service you printheads and rollers both manually with solution and cotton buds (q tips) and then see if your ink may be low or out, blocked printheads will obstruct ink from flowing at all. So will damaged printhead points on cartridge, signalling replacement time.
Posted on Aug 16, 2007
Silan
  • 54 Answers
SOURCE: Paper Jam message when NOT jammed
Close all the running programs/applications on your computer.
1. Click Start --All programs - HP - HP Director/Solution center.
2. In Hp Director/Solution center Click Start - Settings - Print Settings - Printer Settings
3. Click on the Features tab. Set the Paper Type to Plain paper and Paper Size appropriately.
4. Click Ok. Close HP Director/Solution center.
Open the application and try printing.
Thank you.
Posted on Dec 23, 2007
cropp
  • 377 Answers
SOURCE: Problem with HP 7450 and "Paper Jam"
hi, mezz
try this
There are 2 different types of flashing patterns with those two lights on the printer.
Resume light and power light BLINKING ALTERNATELY
Problem: Paper is jammed in the printer.
Resume blinking SIMULTANEOUSLY with power light
Problem:
The print cartridge carriage is stuck.
Solution:
1. Open the top of the printer.
2. Remove anything that is blocking the carriage path.
3. Turn the printer off.
4. Turn the printer on.
Problem:
There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
Solution:
If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
Unplug the power cord from the back of the printer.
Wait about 30 seconds.
Plug the power cord back into the wall outlet.
Plug the power cord to the back of the printer.
oke, post in me back
tq
cropp
Posted on Mar 16, 2008
  • 12 Answers
SOURCE: continuous paper jam when i try to print
Hi ,
Follow the steps below -
1. check the media / paper compatibility. It sould be as per hp :
Paper tray capacity Type Weight Capacity Input tray Capacity Output tray Plain paper 60 to 90 gsm (16 to 24 lb) 150 50 (20 lb paper) Legal paper 75 to 90 gsm (20 to 24 lb) 150 50 (20 lb paper) Cards 200 gsm (110 lb index max 30 30 Envelopes 75 to 90 gsm (20 to 24 lb) 20 10 Transparency film N/A 25 25 or fewer Labels N/A 30 30 4 x 6 inch (10 x 279 mm) Photo paper 236 gsm (145 lb) 30 30 8.5 x 11 inch (216 x 279 mm) Photo paper N/A 20 20 Paper sizes Type Size Paper Letter: 216 x 279 mm (8.5 x 11 inches)
Legal: 216 x 356 mm (8.5 x 14 inches)
A4: 210 x 297 mm
A5 148 x 210 mm
Executive: 184.2 x 266.7 mm (7.25 x 10.5 inches) Envelopes U.S. 10: 105 x 241 mm (4.125 x 9.5 inches)
A2: 111 x 146 mm (4.4 x 5.8 inches)
DL: 110 x 220 mm (4.3 x 8.7 inches)
C6: 114 x 162 mm (4.5 x 6.4 inches) Transparency films Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Photo 102 x 279 mm (4 x 6 inches)
127 x 178 mm (5 by 7 inches)
Letter: 216 x279 mm (8.5 by 11 inches)
A4: 210 x 297 mm (8.27 by 11.7 inches) Labels Letter: 216 x 279 mm (8.5 x 11 inches)
A4: 210 x 297 mm Custom 76 x 127 mm up to 216 x 356 mm (3 x 5 inches up to 8.5 x 14 inches) Print margin specifications Paper size Top Bottom US Letter
US Legal 1.8 mm (0.07 inch) 3 mm (0.12 inch) ISO A4
ISO A5
JIS B5 1.8 mm (0.07 inch) 6.0 mm (0.2 inch) Envelopes 1.8 mm (0.07 inches) 14.3 mm (0.5 inches) Cards 1.8 mm (0.07 inch) 6.7 mm (0.3 inches) 2. paper should be placed to the right of the tray and a little inside with a min distance within the papers of .1 mm
3. open the rear access door of the printer (with grids) on the back and reval the rollers. Take a slight moist cloth ( not cotton ) and clean the rollers with it by moving them 4 times upwards.
4.open the cartridge door ad observe the thin plastic strio on top of the steel rod on which the carriage moves. Take a small piece of paper and hold the strip with it ands swipe it once witout applying much pressure as it could come out in any direction and as much as you can
5. make sure you replace the cartridge if its refilled. It could provide obstruction.
move the carriage 4-5 times continuously with as much speed and make sure there is no obstruction in the carriage movement.
6. press set up button on the printer panel - go to print reports - ok / enter - self test report - see if the paper jams. If not good.. If yes take a look into the next step.
7. pull out the power cable directly from the printer. Press and hold # and 6 button on the printer and insert the power cable and do not release the buttons till you see te display glowing blank or some processing happening. Release the #6. If the printer turns off then press on the power button to turn it on. Continue with country and language settins as apprpriate. Choose your country during this reset. Complete the alignmet then. Take a printout to see if the paper jams again.If yes - the printer definitely needs servicing.
Posted on Apr 08, 2008
leroyal
  • 2120 Answers
SOURCE: paper jamming behind the toner cartridg every time i print
Open the rear door and check for jammed paper between the fuser and exit assembly. You will need a flashlight
Posted on Mar 12, 2009
Red light is constantly blinking and when try to print, there is always a paper jam
Every time there is paper jam, the printer knows the job is not completed and hence tries to re-print after the paper is removed and cover is shut.
Clear the print job from computer.
Power off the printer and Clear the paper jam (if any)
I would try to use different tray. The paper pickup roller in one path may be worn out.
eg Sheet feeder or multipurpose tray.
Load paper in new tray
Set the application to use new tray
Ensure you sue the right thickness (gsm) of the paper. Quality of paper is crucial. Too thin; too thick can affect functioning.
Mar 16, 2016 | Ricoh Aficio Sp 3300DN Laser Printer
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
Paper Jam message on every print job.
I have the same printer without the doc feeder. Check the paper trail thru the printer for the paper sensor lever hanging up. It gets pushed up by the paper and can stick, making the printer think it still has paper in it. Pulling the cart unsticks it till you print again.
Jul 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Paper jamming behind the toner cartridg every time i print
Mar 12, 2009 | HP LaserJet 3390 All-in-One Multifunction...
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Thank you.
Dec 23, 2007 | HP PSC 2410 All-In-One InkJet Printer
23 people viewed this question
Seeker5211
Seeker5211
