The Arcitec shavers have a poor design which makes it difficult to clean well. The blades can not be removed from their combs, therefore, the only way to clean this is by running them in a cleaning solution. Norelco makes a shaver cleaned that can be used for this. It is available from shaveroutlet.com at the link below. Rubbing alcohol can also be used.
Simply fill a container about 1 inch deep with the cleaner and then stick the shaver head down into the liquid with it running. Run for several seconds, remove and repeat several times.
Note that if your shaver is badly clogged, this still may not work that well due to the poor design of the shaver heads. If you require replacement, you will also find them at shaveroutlet.com. See link below
The problem is the base, not the shaver. Most likely, the circuit board inside the base has gotten wet and is damaged. If this is the case, it will need to be replaced. You will find a replacement at shaveroutlet.com. See link below
The self-cleaning shavers are all much more expensive to maintain than traditional non-self-cleaning shavers. Your model 8985 is not inherantly more expensive to maintain than any other self cleaning model by Braun or other brand. The cleaning solution is expensive, the cleaning machines break because of exposure to liquid, and the heads often wear out faster as well.
Because of this, I strongly suggest you buy a shaver without a self cleaning machine. Most models that do not include self cleaning machines are very easy to clean with an old toothbruh dipped in rubbing alcohol. If you liked the way the Braun shaved when it was in good condition, I would suggest the following models linked below as possibilities
