Question about Fujitsu Siemens LifeBook S7010 Notebook
Laptop switch laptop won't switch on, i think the switch is faulty......my question is how do you replace or fix it. i am a technician but fix destop machines all the time and this is my 1st laptop problem.
  • 89 Answers
If the switch is faulty and this is very unlikely then you need model number so you can order the switch. Servicing laptops is not all that different from desktops - just smaller and more of a pain. You may want to remove the battery, unplug the system, then reinstall battery and plug it back in to see if you get anything. I am assumimg from your post that you get NO power at all.
Posted on Oct 27, 2007
My ProBook 4710s won't turn on it has a blackscreen. how can i fix this?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 17, 2013 | HP ProBook 4510s FM849UT Notebook
Acer laptop 5551 wont charge
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Replacement Acer Aspire 5551 AC Adapter 65Watt 19V 3.42A
Feb 17, 2013 | Acer Aspire Computers & Internet
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Macbook pro resets every time it runs out of power
Your laptop contains a small battery (aside from the regular battery) that saves CMOS information like time/date and a few other settings.
When your computer loses all AC/battery power, the settings are reset to factory.
You'll need to replace this battery, normally it is a regular disk battery that can be purchased at any hardware store.
If you're not tech savvy, you can have a professional technician open up your macbook and it won't cost much more than $100.
May 16, 2012 | Apple aluminum 13-inch MacBook laptop-...
My laptop won't charge even it is plugged in.
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Loue Benison.
I think senerio 2 is the most likely, although you will have to test senerio 3 by removing the battery and pluging in your charger and seeing if the laptop powers on.
If it does power on then that rules out senerio 1 and 2 leaving a faulty battery.
Take care!
Dec 14, 2011 | Lenovo G460 Laptop Computer 06774CU Intel...
My Dell Inspiron 15R fan is not working....the laptop gets overheated due to this & shuts down after 15-20 minutes.The laptop has exceeded its warranty period.I had bought the laptop in May 2010.
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
May 28, 2011 | Dell (6F858) Cooling Fan
I have Samsung NP-R505H laptop. My laptop won't
You say it isn't charging, but will it run off of AC power? If it isn't getting *ANY* AC power, then it might be the female end of the power jack on the laptop. If it will run on AC, the culprit is likely to be a battery that needs replaced.
May 13, 2011 | Samsung Computers & Internet
Colour distorted after laptop fell
its better you should take it to the technician, i think the cable that gives signal to the panel has become faulty
Nov 24, 2008 | Acer Aspire 5610 Notebook
Laptop not showing desktop just remains blank when switched on
hi mikkk,
try the following.
1. right click on your desktop (blank screen ). go to arrange icons by--> check show desktop icons. this might fix the issue.
2. or in the task manager. go to file--> new task....Run "explorer.exe" ( type it without the inverted comas). this wud fix the issue.
hope to get rated as helpful.
regards.
bzoy
Jan 03, 2008 | Acer Aspire One PC Notebook
Laptop switch
try to spray the switch with "Contact Spray 90" ur switch maybe oxidised i think it will solve
Nov 28, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Fujitsu Siemens LifeBook S7010 Notebook Logo
215 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
