Question about Health & Beauty
Error 21 no monitoring display. only err and when holding
  • 1294 Answers
SOURCE: Error message wont go away
Press "start" & "cancel" for over 10 seconds. Do not force door, wait for a couple of minutes.
Posted on Dec 02, 2007
  • 1294 Answers
SOURCE: Err Err err err err pau
Press "stop" & "cancel" together for over 10 seconds to clear the display; and continue your..........
And rate me pl.......
Posted on Dec 03, 2007
SOURCE: Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Posted on Jun 23, 2008
SOURCE: Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
websnail
  • 419 Answers
SOURCE: epson rx560 general error
Unfortunately a "general error" is different from the commonly assumed "service required" error.
Usually a general error comes about because of something a bit more serious than a paper jam which stops the printhead from moving around as it should, cartridge chips not reading properly, etc...
It's worth trying the following and seeing if any of them help
  • Open the printer lid and using a flashlight/torch, carefully examine the area that the printhead travels along to see if there's any foreign objects, ink soiled paper, etc.. that might be getting in the way.
  • Try getting the printhead off the parking area and check this for any parts of the cleaning station that may have dislodged or other foreign objects that do not belong
  • Remove all the cartridges, clean the chip contacts carefully with a cotton bud and check the contact wires inside the cartridge holder area for any damage.
Beyond that it's a case of looking for clues that might indicate where the problem lies.. ie: if the printhead stops in a particular place, screeching noises, etc...
Hope some of that helps narrow it down some.
Posted on Mar 26, 2009
My brother dcp 1510 is telling an error massage "replace the toner cartige"i have changed toner ;try to reset but i cant please tell me the exact reset code and procedure .
Hi try this press menu button hit down arrow until u see info on display press OK button hit down arrow until u see reset drum on display press and hold OK button until u see reset on display press start button press-up arrow until u see the value 10 press OK button on display should read accepted press stop until the main menu appear on display.......good luck
Jun 10, 2016 | Brother Office Equipment & Supplies
My odyssey 2003 is showing code err for the entertainment
Does the radio work at all. or is the cd player the only issue.? most of the time you need to enter a radio code to unlock the radio. If you enter it wrong to many times it will display error on the display.if you dont know the code then you can call the dealership and get the code after you do the following below to get the serial number.
Press and hold 1 and 6 on the radio while still holding the 1 and 6 press the power button. At this time it will read off serial number
SOUTHERNELECTRONICS.COM
Apr 02, 2015 | 2003 Honda Odyssey
Hello, I have a Paradigm T801 showing the error message ERR 40 Over Acceleration. Is there any easy fix for that problem?
Reset the machine and proceed wit this steps. God bles you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Oct 02, 2013 | Paradigm Exercise & Fitness
Trimline manual
follow this steps and fix i.t God bless you
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • Sponsored Links
  • 3
  • 4
  • Read more: http://www.ehow.com/how_5731107_reset-treadmills.html#ixzz2gXuRx33v
    Oct 02, 2013 | Exercise & Fitness
    Need to set date and time ozeri bp2m monitor
    1. Press and hold Time button until Hour/Min. flashes
    2. Press Time again; Mon. flashes
    3. Press Scan (down) or Memo (up) until the current month is displayed
    4. Press Time; next field flashes
    5. Press Scan (down) or Memo (up) until the current value is displayed
    6. Repeat steps 4 and 5 until all fields are set to appropriate values
    7. Press Time again; date and time are saved
    May 09, 2013 | Ozeri Portable Cardiotech Premium Series...
    Non paper sense error
    1. Power the unit on while holding the Menu Up + Menu Down + Help buttons, and continue to hold them until "System Maintenance" is displayed.
    2. Press the Menu Down button until "Diagnostic Mode" is highlighted, and then press the Enter button.
    3. Press the Menu Up button until "SWITCH SCAN" is displayed, and press the Enter button.
    4. Press the Menu Up button until "REG L/R_DENS_WEIGHT" is displayed, and press the Enter button.
    5. 4 Hexadecimal numbers will be displayed. Only look at the 4th number. xxx, xxx, xxx, xxx (example: 09E, 27D, 000, 12C) 6. Adjust the 4th number as close to the desired 12C as possible (acceptable range being: 10E ~ 13E) by rotating the adjustment screw (See illustration below).
    May 31, 2012 | Xante Ilumina Digital Color Press Printer
    Could you please tell me what error codes 21 and 6 relate to on a Winterhalter GS502 dishwasher. Many thanks. Barry CER
    error 6 relates to a blocked drain pump. if the drain pump is working ok check if the tank level sensor is operating or if the air chamber in the wash tank is blocked.
    error 21 relates to the drain pump being activated. normally related to error 6.
    also check water inlet solenoid valve is working correctly. ie not blocked or passing.
    all parts of the machine can be activated manually by entering service mode.
    when machine is off press service button or switch on main pcb.
    p00 appears. press and hold main wash button. --- appears. using the long and short wash buttons you can scroll through parts of the machine. displayed as a01 a02 a03 etc.drain pump is a12 solenoid valve is a13. these are activated by pressing the button. when activating the drain pump the display will count down. this number is the water level in the wash tank. if it's counting down the level sensor is ok.
    hope this helps
    jarv
    Mar 29, 2010 | Dishwashers
    Setting the time
    It took us 2 days, but my husband and I finally figured this out.
    Press and HOLD the Mode button until the time display starts to flash. Press the mode button again until the hours are flashing.
    Use the Stop/Start and Reset buttons to move the time up or down.
    Press the mode button again until everything stops flashing.
    Oct 16, 2008 | Reebok Fit Watch 10M Strapless Heart Rate...
    COPIER KIOCH FT5840
    Hello Woolfmoon.Despite the fact I have long since thrown away all my documentation on this machine since is an analog machine and is quite old (but a good machine),and despite the fact that I cannot tell you the entire specifics of that particuliar erroe code because I dont have the manual,and despite the fact that I am graded on how well I help you out and "FIXYA", I will give a decent accessment. SC 544 has to do with the fuser. A temperature error ocurred (under/over.....time frame). Because of the intense and potentially dangerous heat that is intentionally generated @ the fuser there are many aspects of the fuser's characteristics that are monitored. Even general power conditions in the copier's enviroment can cause the safety monitors related to the fuser to generate an error as the safeguards are very sensitive. You can reset the code in the event it was generated erroneously or the problem has been resolved. Your copier has to believe that a "technician" fixed the problem so I will tell you how to do that. Press "clear/modes(yellow button) , then press the numbers "1 0 7" and then press the round orange stop button and hold it down until you see the the display change and begin to flash. For example the display area that would normally show you the number of copies you had requested should be flashing if you had successfully entered "service mode". So to be nore clear.......use your index finger as your brain and press CLEAR/MODES then 1 then 0 then 7 then hold down orange start button foe several seconds till the display changes. THEN....... :-)........turn off the main power (if you are in doubt unplug that baby). This will tell the copier to chill out and try to reboot again as if nothing was ever wrong. But if the problem still exists the copier will shut down again and give an error code. If that occurs you have a genuine and potentially dangerous problem in the fuser. I hope I helped a little, and wish to have helped you alot. Take care. Let "Fixya" know if I was of any help at all please.............SPINAL
    Apr 08, 2008 | Office Equipment & Supplies
    ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
    ERR=An error has been detected
    PAU=Cycle has been intrupted
    58=High current on motor phase
    To clear latest stored error code:
    • Turn the Program Knob to the start position, Spin Only.
    • Press Start/Pause to start the cycle and save it.
    • Press Cancel to stop the cycle and turn off the LEDs.
    • Press Cancel again to turn on the LEDs.
    • Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
    • Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
    • Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
    • Exit Diagnostic Mode to return the washer to normal operation.
    a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
    b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
    together for a few seconds until wash cycle LEDs appear.
    Feb 25, 2008 | Washing Machines
    Health & Beauty Logo
    26 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
