Question about Motorola RDU4100 Two Way Radio
Progrham RDU4100 to Spirit MU21CV
I neeed my RDU4100 and Spirit MU21CV to work as 1.
  • Motorola Master
  • 1,654 Answers
4 Suggested Answers
eradiostore
  • 1654 Answers
SOURCE: motorola spirit mu21cv
Sounds like you do not have your radios programmed to match one another. The MU21CV is a user programmable model. You might call your local Motorola dealer or one of the companies online to have someone walk you through programming the radio(s). With this model it can appear the radio is not powering up, when it simply is not programmed correctly.
Posted on Jun 24, 2008
  • 56 Answers
SOURCE: programing radios
The XTN will not work with the spirit. The PL tones are worng.
Posted on Jul 22, 2009
SOURCE: where can i buy battery terminals for my spirit mu21cv walkies
I have boxes of used boards for the MV and MU radios. If you want to un solder the battery terminals, they are yours for the cost of shipping. Up to six boards. I also have new terminals in stock: radiodude365@yahoo.com
Posted on Sep 24, 2012
Where can i buy battery terminals for my spirit mu21cv walkies
Your local Motorola radio dealer should be able to help you with this.
Mar 23, 2012 | Motorola MU21CV (1 Channel) 2-Way Radio
Will the MU21CV radio's work with the talk about radios?
Short answer, maybe. It depends on whether you have a 14 channel or a 30 channel Talk-About. The Motorola Talk-Abouts operate on the FRS frequencies (14 channel) or FRS & GMRS frequencies (30 channel). The MU21CV does cover a few of the GMRS frequencies. (see bold numbers)
GMRS Frequencies
462.500, 462.575, 462.600, 462.625, 462.650, 462.675, 462.700, 462.725, 467.550, 467.575, 467.600, 467.625, 467.650, 467.675, 467.700 & 467.725
FRS Frequencies
462.5625, 462.5875, 462.6125, 462.6375, 462.6625, 462.6875, 462.7125, 467.5625, 467.5875, 467.6125, 467.6375, 467.6625, 467.6875, 467.7125
MU21CV Frequencies
464.500, 464.550, 467.7625, 467.8125, 467.850, 467.875, 467.900, 467.925, 462.575, 462.625, 462.675, 464.325, 464.825, 469.2625, 469.500, 469.550, 462.7625, 462.7875, 462.8125, 462.8375, 462.8625, 462.8875, 462.9125, 464.4875
Nov 01, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
When i try to talk on another motorola spirit mu21cv it makes a cracking/static sound and it transmits what im saying but i have to have it very loud for it to work and even then it makes a very loud...
Two things come to mind. First, you may have a bad battery. It is typical for a bad battery to cause the radio to have static, or poor transmit. Second, you may not have the radios set to the same frequency as one another, or one is on a narrowband frequency, and the other is wideband. (Depending on the age of the two units.)
Try switching the batteries between a working radio and the staticy radio. See if the problem moves to the other radio. If so, replace your batteries.
Check your programming, if you don't know how, contact your local Motorola dealer or give us a call (google our name). We can walk you through programming over the phone.
Lastly, if all these suggestions fail, your radio may be in need of repair. Flat rate repair is currently around $69 ea.
Best regards.
Oct 18, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Is the motorola MU21CV a UHF or VHF??????
MU21CV is a UHF radio.
MU= UHF
MV = VHF
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/Spirit_M_Series_E.pdf
You can find a frequency chart on page 10.
Best regards.
Jan 11, 2010 | Motorola MU21CV (1 Channel) 2-Way Radio
Transmit button on the lapel mic will not key the radio
Two things which come to mind, one would be if the PTT on the remote mic is bad/defective, second would be you are plugging the audio device in with the radio turned on.
If your remote mic is failing, the PTT is a repairable item, as is the cord on most models.
Mar 30, 2009 | Motorola MU21CV (1 Channel) 2-Way Radio
Programing radios
Feb 21, 2009 | Motorola Walkie Talkie 2-Way Radio
Compatability
would a MU21CV be a VHF or UHF????
Aug 12, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
MU21CV
It is likely your radio needs a new rechargeable battery.
Jun 24, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola spirit mu21cv
The problem of failing to power on can be caused by:
1. dead battery (may no longer hold a charge);
2. corroded battery terminals or connectors;
3. open wiring from the battery casing to the internal circuitry;
4. defective on/off switch; and/or
5. defective regulator component(s) on the main PCB.
On the other hand, problem on receive can be caused by:
a. defective or worn out volume control (if manual/rotary);
b. defective or worn out squelch control (if manual/rotary);
c. mismatch in PL or CTCSS code; and/or
d. defective internal speaker.
Most can be checked with the use of a continuity tester or a DVM. Repairs involve knowledge and familiarity with electronic components and circuitry and perhaps even the use of a soldering iron. Should you not be comfortable doing it yourself, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola RDU4100  Two Way Radio Logo
57 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
