Question about Whirlpool Washing Machines
Whirlpool AWO/D049 not spinning - Whirlpool Washing Machines
5 Suggested Answers
garing
  • 998 Answers
SOURCE: AWO/D4305 Does not spin
its not hard to put in yourself if you lay it on back and work from bottom..... est. motor cost is 130 to 150 dollars
Posted on Aug 06, 2009
  • 27 Answers
SOURCE: whirlpool gb awo 3551 is not spinning of its
it cant work
Posted on Feb 21, 2010
  • 6277 Answers
SOURCE: Have FP showing in time
'F'- filter, 'P'- pump?
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 23, 2011
SOURCE: how to replace belt on Whirlpool AWO/R4205
Whirlpool AWO/R4205 service light comes on when started
Posted on Jun 01, 2013
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Whirlpool awo r 5206
spin it 30 degrees back simple
Nov 03, 2013 | Washing Machines
When on spin the drum bangs is there a burning AWO/D 4605 ser end 104
Sounds like its just out of balance, the feet(1 at each corner) should have threads so you can balance it better by unscrewing or screwing back in as needed. Place a level on top of washer and see how out of balance it is and what corners you need to raise
Sep 24, 2012 | Whirlpool Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
Aug 06, 2009 | Washing Machines
Washing Machines Logo
64 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
