Question about 2002 Chrysler Concorde Fuse
Where is the highbeam headlight fuse in the fuse box
    New Friend:
  • 20 Answers
Hi and low normally same fuse
Posted on Jul 20, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
What could be the problem with my headlights.
sounds like a fuse or relay ,have you checked the fuse box drivers side lower dash for headlight fuse(s) also in engine bay there is another fuse box with relays ,list will be on the cover ,i'd start there as power is going to bulb on one circuit , other than that the switch may not be working fully
May 14, 2014 | 1999 Pontiac Grand Prix
Headlights won't turn off
The weird noise is the relay for the headlights. You need to locate the relays and replace them. They are in the fusebox that is under the hood.
Dec 02, 2013 | 2002 Toyota Rav
Rf highbeam doesnt work,after new bulb install 02 monteSS
Check for 12VDC at the connector with your high beams on. Could be the wiring or the connector and no they run on the same fuse.
Dec 30, 2012 | Cars & Trucks
High Beams stopped working, no voltage at the fuse box
It can be the bulbs itself, or the fuse, or the highbeam relay.
Did you check the fuse of the high beam which should be located under the hood, or the headlight switch fuse which is usually inside the interior fuse box?
Aug 26, 2012 | 2002 Kia Sedona
No highbeam
Is the headlight out?
Did you check the connections/wiring to the headlight bulb?
Did you check the fuse?
Is it just one highbeam?
Or are both highbeams on both sides of the car out?
What year Toyoyta?
Oct 16, 2010 | Toyota Cressida Cars & Trucks
My headlight-high beam does not work . its just that the highbeam does not come on
Probably the highbeam switch itself but check to see if there is a seperate fuse for the highbeams and if it's blown figure out why
Oct 02, 2010 | 2002 Volkswagen Passat
My co worker tried to replace a few fuses in the fuse box now the highbeams don't work in our ford e350 van we dont have the owners manual to locate the fuse and was wondering if anyone knows the location...
SOUND LIKE HEAD LIGHT RELAY BAD.LOOK UNDER THE DRIVER SIDE DASH BELOW THE STEERING COLUMN FOR FUSES AND RELAY.YOU HAVE FUSE AND RELAYS UNDER THE HOOD IN THE ENGINE COMPARTMENT ALSO AROUND FENDER AREA.
May 13, 2010 | Ford E-350 Super Duty Cars & Trucks
Headlights dont work, but park lights and signal lights do. all fuses in passenger kickpannel are good. Is there anoyher fuse box.
there should be another fuse / relay box under the hood - the headlamps will probably have a fuse and a relay. if the fuse is ok - try swapping the headlamp relay with another in the box - if all is ok start looking at the headlamp and or highbeam switches
Oct 24, 2009 | 1998 Jeep Grand Cherokee
Both Headlights Won't Work
the fuse is 20Amp. and the fuse box is located under dash next to the hood pull in the driver side.
Mar 30, 2009 | 1992 Lexus Sc 300
2002 Chrysler Concorde Fuse Logo
54 people viewed this question
Top Littelfuse Vehicle Parts & Accessories Experts
baire
ARESTI
ARESTI
David Ellis Rhea
Are you a Littelfuse Vehicle Part and Accessory Expert? Answer questions, earn points and help others
