Question about Staples TXC122ACC Cross-Cut Shredder; 12 Sheet
Won,t shredd in auto or forward
Won't shred in auto or forward, but runs in reverse
2 Suggested Answers
gunzzzz
  • 391 Answers
SOURCE: Why is my ID Armor ID-XC200D making a horrible noise when I shred?
kkrenn641:
That "horrible noise" is probably caused by the shredder gears meshing improperly. If you disassemble it again and look carefully at the gears, you will most likely see that some are not mating properly... Usually the motor gear and the first idler gear that meshes with the motor gear. If those two gears seem to be separated a bit, or slightly mis-aligned look carefully at where the motor mounts, and you may see that the plastic "bed" where the motor is mounted has melted from heat from the motor. This is caused by using the shredder too long without letting the motor cool down. You may be able to shim the motor housing to realign the gears, if you have the patience!
Posted on Sep 15, 2012
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
I have a staples SPL826X shredder and it won`t shredd, but it will go in reverse. can someone help me?
If you can disconnect the power to unit and check shredding blade alignments to see if there is a clog or if the blades are out of alignment and stuck. If there doesn't seem to be a problem with the blades make a visual inspection of the off/on/reverse switch.
Nov 28, 2014 | Staples SPL826X (CrossCut) Shredder
My kobra shredder won' shred when we put paper in lights are on
Is the discharge at the bottom where the shredded paper comes out clear? If its blocked by paper etc, it will not shredd.
Aug 19, 2014 | Office Equipment & Supplies
How do I fix my blades on my shredder?
Try running a layer of aluminum foil between two sheets of paper. See if it shredds, If it does, do it a couple of times, then use shredder oil. It might help to both sharpen the blades, and to keep them sharp longer. It works on cutting blades for scrapbooking cutters and scissors...
Aug 18, 2014 | Shredder Secure Shred Shredder
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Forward shredding will not run, no jam, reverse will run.
The switch usually only reverses the polarity of the motor, making it run forward or reverse. If the motor runs one way and not the other the one side of the switch is faulty and needs to be replaced.
May 31, 2011 | Office Equipment & Supplies
Have ativa dx1800u. It will move in reverse, but will not go forward to shred. Specifically, I will run in reverse and then when move to auto and place paper in, a sensor picks up paper going in and...
I work for Office Depot and the Ativa brand we get a lot back with this problem. It is a electrical problem in the sensor and all you can do is get a new shredder.
Dec 23, 2010 | Office Depot Office Equipment & Supplies
SB-97Cs Full red light stays on
You can order from Fellowes or a dealer like myself. Maybe the unit is all jammed up with shreds in the housing. Try taking the top off and cleaning it throughly. Be careful with the short ribbon cabl.
Jun 19, 2009 | Fellowes Manufacturing Powershred SB-97CS...
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Staples TXC122ACC Cross-Cut Shredder; 12 Sheet Logo
124 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Steve P
Steve P
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
