Question about Cyclops Camping, Backpacking & Hiking
Need a replacement battery for a thor 10 million candle power spot light
3 Suggested Answers
CarlGlas
  • 283 Answers
SOURCE: I have a Sport Spot
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Or you may find one here: http://www.batterywholesale.com/battery-store/SLA-batteries/
Posted on Nov 03, 2010
  • 172 Answers
SOURCE: i need a lead acid
If you pull the battery, you should be able to match it at a battery specialty store like BatteriesPlus or The Battery Store (both are chains in my area that sell specialty replacement batteries). Someone there should also be able to suggest alternative batteries if an exact match can't be found. It's almost certain that multiple manufacturers make a battery with comparable voltage and amperage characteristics; the finicky part is finding a battery that has the right terminal placement.
It's worth looking at substantially similar batteries. Sometimes, a battery with slightly different terminals will cost a fraction of the price of an exact match. If that's the case, it may be worth your while to engineer a little adapter wire so you can use the cheaper alternative in your light.
On a final note, once you know the standard description for your battery, you can often find the cheapest replacements online. Speaking generally, this size lead-acid battery is used in many UPS devices, though those cells may have different terminals. However, if you go shopping online, be aware that the cost to ship a lead acid battery may eat up any savings in price from shopping locally. In addition, if there's a problem with the replacement battery, it will be more difficult and more expensive to return/exchange it than if you purchase one from a local shop.
Posted on Jul 13, 2011
Bad blub where do i get another
These spotlights are, essentially, automotive headlights powered by small batteries. Accordingly, take your old bulb to an auto parts store and match it to one of the headlight bulbs they carry. You'll find many bulbs that look just about right; the key is to find one (or more) that has the exact same base as your bulb so that it'll just plug right into place.
Before buying a new bulb, you can also double-check your old bulb with a simple test for continuity. Properly treated, these bulbs have a reasonably long life, and I wouldn't rule out corrosion in the bulb socket or some other issue that's keeping your bulb from lighting up. Of course, if you can see the torn or burned out bulb filament, it's pretty obvious that you're going to need a replacement.
Jun 02, 2011 | Cyclops CYC-S250 Thor 2.5 Million Candle...
Where can I find a replacement 120v ac adaptor for a Thor X flashlight?
My Thor X 10 million candlepower spotlight takes a standard 12 volt, 1500 mA, center positive AC adaptor. You should be able to find one with an appropriate tip at any Radio Shack store, but you may find a cheaper universal adaptor at a Walmart or even at a "Dollar Plus" kind of store. An adaptor with a lower mA rating will take longer to charge your light, but it should still work (down to about 750-800 mA, I'm guessing).
Double-check the charging port of your Thor light to see whether there's any information about the input voltage requirements. On mine, the light itself has the charging port labeled for 12v, though I was reading the more detailed specifications off the adaptor itself. I can't recall whether the 2.5 million candlepower light also uses 12 volts of power (I think it does), or whether it takes 6 volts (a single battery vs. two batteries wired in series).
May 18, 2011 | Cyclops Thor 2.5million Rechargeable...
I have a Sport Spot 20 million candle power light .I need a battery for it .Battery number NTO609(6v6 OAH/20HR). Where can I find it, and how much will it cost?
Sep 29, 2010 | Vector 2M Pwr Rch Spotlight
We have a V Vector spot light 3,000 candle watt and need a new battery. The original is a SEL DMU 6-6 6VAH.
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Aug 04, 2010 | Vector 2M Pwr Rch Spotlight
How do i find charger for cyclops 15 million candle power
INPUT: 120VAC 60Hz 18W
OUTPUT 12VDC 1A.
This is the spec for the 18 million thor cyclops which i presume will be the same for the 15 million.
Red light on torch flashes while charging. As soon as full charge is done red light stays lit.
May 19, 2010 | Camping, Backpacking & Hiking
I need 3 light bulbs for a 3 million candle power spotlight from Gordon 12Volts
Hello! I have a marinepro, 12-volt, 3 million candle power spotlight (mpn #MPAT-996). I found out that the manufacturer is RoadPro (866) 622-7979. After contacting them, they said the replacement bulb is an "H3 12v (volt) 100w (watt) and can be found in the Walmart camping section or should be available at any car parts store. I'm going to go to Walmart to find mine. Hope this helps others!
Mar 08, 2010 | Vector 3 Million Candlepower Rechargeable...
Spot light doens't work
The battery is probably defective, take the battery out and test it, it should be at 12 volts.
Feb 28, 2010 | RoadPro 1M Candle Power Spotlight 12V
I have been charging my 2 million candle power spot light for last 2 days but full battery charge indicator (red light) does not flash yet. the led white light is working but the main lamp doesn't work....
It should take 10-12 hours, any longer the battery is no good, you can test the battery using a Volt Meter, the battery should be reading 12 volts, any less and the battery will need to be replaced. You can order a new one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Feb 13, 2010 | Vector 20 Million Power Series Spotlight
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Camping, Backpacking & Hiking Logo
37 people viewed this question
Top Cyclops Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Cyclops Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
