Question about Air Conditioning and Heat for GMC Terrain
Air flow will now come out of upper vents
Air flow will not come out of upper vents
    Sergeant:
  • 406 Answers
There are air sensors that open/close and mix the air...this is one of the GM product problems I have the same thing on my 2003 Sanoma..there are easy fix ones and unfortunately mine is the hard fix requiring the dash removal..the other is a door spring or plastic piece broken..can be seen just under the dash where the sir box is..easy fix..have it checked that is the common problem..Hope the best and good luck..
Posted on Oct 03, 2014
Central heating does not work well upstairs
You need to restrict air flow to lower level vents to allow more air to be forced into upper level. Air will follow the least resistant path.
May 26, 2012 | Heating & Cooling
2005 Silverado 2500HD 4WD - It appears that the pneumatic valve controlling the directional air flow from my heater/AC is getting stuck. When I switch the fan to front window defrost then back to...
The default configuration when all vacuum fails is to defrost vents. Most likely your vacuum supply to the switch is weak. Check the connection of the supply line to the intake manifold for damage. If no problem there, trace it to the switch on the control panel. If there is an accumulator, make sure it isn't leaking and is storing vacuum. If all this is good, look at any other vacuum lines connected to the intake manifold that may be leaking and possibly reducing the vacuum supply to the HVAC control line. Let me know if you have more questions.
Sep 28, 2010 | 2006 Chevrolet Silverado 2500HD 2WD
Air flow out of A/C (HVAC) seems to be partially blocked. Noise increases with increased fan speed settings, but flow barely changes. Even on maximum setting the flow is not enough to reach driver or...
One of the Actuators for the doors inside your dash that controls and diverts air might not be working correctly. You may have to either replace the Actuator or Replace the A/C Heater Control. Your vehicle does not come with a Cabin Air Filter.
Jun 26, 2010 | 2004 Dodge Ram 2500
Milk lunch meats freezing
I have to assume you mean on the top shelf of a refrigerator. If so, then you need to look for the air vent(s) that are usually in the rear of frig compartment either on back wall or under the frig compartment ceiling. These vents are pouring very cold air from the freezer and the air needs to get distributed throughout the frig, however the coldness is falling on the milk or meats that are in the way (getting hit with the cold before the air is disipated within the frig).
Three options: if the air vent(s) have a movable or directional cover, then redirect the air so it blows away from the food on the shelves. If there is no movable cover, perhaps adjusting the freezer control (not the frigerator control) to the next colder freezer setting; this will reduce excess cold flow pouring into the frig. 3rd, make a shield of plastic or metal or cardboard to divert the direct cold flow of the air vent from falling on the upper shelves.
Oct 11, 2009 | GE PSC23MGMBB / PSC23MGMCC / PSC23MGMWW...
Blower good, air flow comes out bottom and not out upper vents, also air flow will not come out defrost vent gerald
vacuum or acuator motor is the culpret,look under hood and make sure vacuums all conected and vacuum going threw them, parts store will know if there is an acuator motor for that year/check for a vacuum resorvior .round like a ball or made like a can it may have vacuum off of it or it may have a hole in it
Jun 29, 2009 | 1990 Cadillac SeVille
Fully warmed up; blowing hot and cold; Suzuki XL-7
Its just a vent damper plate not operating, it's like a gate which controls the flow of air,,usually they are operated by vacuum, or cables.
Service center time, unless you are handy with your own repairs.
Jan 19, 2009 | 2004 Suzuki Verona
Heat wont blow through heater or defroster vents
common problem, check under dash by the gas pedal if control arms are muving went selecting from ac to heat cuz this it is the control for the vents to go from ac to heat and to defrost.
Jan 18, 2009 | 1997 Chevrolet K1500
Freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Dec 31, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Air Conditioning and Heat for GMC Terrain Logo
238 people viewed this question
Top GMC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
alibaba69
Are you a GMC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
