Question about Panasonic PT-61DLX75 61" HDTV
Where is the lamp is in front or back on to model pt61`lcz7 help please
Where in the tv do you replace the lamp on panasonic tv model pt61lcz7 please help need to replac lamp dont know how or where it is on tv
SOURCE: how to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Posted on Sep 04, 2008
SOURCE: Panasonic PT-50DL54J DLP TV Flashing Light
I had the same problems that most of you have been having, tv turning on and off, lights flashing in all different colors, having to unplug tv to reset and all of that good stuff. I noticed that most of the time this would happen once the tv would start to heat up, and I could hear the fan working a little harder. Well I am not an electrician but It was very simple to unscrew the lower bottom park of the tv, where the fan and most of the electronics sit, then I used an oxygen tank ( I work for a medical company ) to blow out all the dust in the tv, ( you can olso use the compressed air use for computer, but if grandma or grampa have some O2 laying around, it works really good, LOL. )and was very surpriced to see how dusty it was, then I removed the MAIN FAN ( you only need to remove three screws, however there's a box in fron of it, which you'll have to remove first in order to get to the fan ). this may sound a little complicated, but trust me it is not, once you have taken the fan off, clean it all the way around ( best to use a clean rag, the compressed air was not doing the job.
long story short, once I cleaned the fan and put it all back together. The TV still didn't work LOL, Just kidding, It has been working perfect for a little over a week.
If I can help in any other way, please e-mail me @ gsierra11@yahoo.com
hope this helps.
Posted on Feb 19, 2009
  • 13 Answers
SOURCE: Panasonic HDTV 1080i Lamp out
If the lamp is actually out - replace it - if the lamp is still working just reset the lamp hours - at 10,000 hours it automatically says that but it is just the lamp time needing a reset.
Posted on Jun 02, 2009
SOURCE: Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
asnowman
  • 788 Answers
SOURCE: Panasonic LCD Lamp Replacement
Here is the manual for your set, the instructions for replacing the lamp are on pages 66-67.
You can download the manual here.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-61LCX65
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Aug 21, 2009
Testimonial: "Just what I needed and fast. Thanks."
Replaced projection lamp in panasonic multi media projection television and reset timer t_v played for a day or so then cut it off now power will not come back on green light is blinking on power
Make sure the Lamp door is tight. Unplug the TV, and remove the lamp and then reinstall the lamp making sure the door is tight. Then plug the TV in and try again. If it does not work, please post the model # of the TV.
Jun 03, 2015 | Panasonic Televison & Video
Do you need a technician to install the lamp bulb for Panasonic PT61LCZ7? Also where can you find that bulb for sale?
Hello
It will be best to change your TVs lamp bulb with the help pf any experienced serivce technician. Normally you can get the bulb from any panasonic spare parts shop nearby you, or at authorised service center of panasonic. It will cost little more when you buy it from the authorised service center, but you can make sure that the part you gets will be genuine one. OK.
Feb 22, 2011 | Televison & Video
My panasonic pt 40lc12 40 inch was on and watching cartoons and made a loud pop and then turned off what is the problem with it just a lamp please help
Check the lamp. It should be a square door for the lamp on the side, back or the front of the TV. Read the user's guide. Make sure to turn the TV off when removing the lamp!. Good luck.
Nour Sabre
Nov 03, 2010 | Panasonic PT-40LC12 40 in. LCD Television
How do I reset the metter for a new lamp?
According to the lamp manual you just need to power the set on with the remote and then press (and hold) the Vol - button on the front of the set, While holding the Vol- button on the front of the set press and hold the PIP button on the remote. HOLD both for more than 5 seconds or until the lamp timer has been reset to 0 appears on the screen.
If this solution works let me know by voting for this post. If not then let me know.
If you need further assistance or if this did not help you please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Dec 06, 2009 | Panasonic PT-52LCX66 Projection Television
How do you reset the lamp clock on model number
asnowman
Nov 26, 2009 | Panasonic Televison & Video
Replaced lamp-orange lights still flash.....lame!
Yes, Turn On TV, press and hold Volume Down button on TV front and Split button on remote at same time for 6 seconds to reset lamp timer in TV.
Sep 19, 2009 | Panasonic PT-43LC14 43" Rear Projection...
No screen at all, does not come on.
If you haven't replaced the lamp yet, that is the first thing to try. Its not hard to do at all.
You can get the lamp just about anywhere on the web.
Here is a link to one site
http://lamps-dlp.com/ProductDetail.asp?PartNumber=TY-LA1001&A=G&B=LA1001
Here is the procedure for replacing the lamp.
Unplug the unit from the wall and wait for all the lights to stop blinking. Ensure that the lamp and the area around the lamp has cooled.
Remove the front cover of the set. You should be able to see the lamp door at this time, loosen the screw and remove the door. You will now have access to the lamp, loosen the lamp screws and remove the lamp cartridge. Reverse the above process and you should be back in business.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a the highest FixYa rating (Give it Two thumbs up). If not then please comment to this post and I will try to help you further.
Thank you for your support.
May 23, 2009 | Panasonic PT-52LCX66 Projection Television
Need to replace lamp cant figure out how to take out
on the front of tv set there is a panel that you unscrew to get to the lamp then once you get that done you have to go through the back of tv to remove and yes you can buy the bulb by itself but you have to order it or any tv repair place might have one in stock
May 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-61DLX75 61" HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
