Question about Car Audio & Video
Lanzar sd76mubt CD player color code for the main unit the ISO connector
Just the ISO connector
2 Suggested Answers
  • 2559 Answers
SOURCE: showe me a diagram of main plug wires on lanzar SD76MUBT
Contact t lanzar for a replacement harness.
Posted on Oct 17, 2016
HOW TO ADJUST THE MIC VOLUME WHEN USING PHONE
Just turn off the Mute button. It is a microphone symbol with a line through it. The feature is there so you can talk to others whilst listening to your caller. The volume control up button might also help
Failing that ask the maker.
http://www.lanzar.com/sku/SD76MUBT/7-TFT-Touch-Screen-DVDVCDCDMP3CD-RUSBAMFMRDS-Receiver-with-Bluetooth-System.
Nov 14, 2015 | Lanzar SD76MUBT Car Video Player
Installing the Lanzar SD34MIP stereo
ground the emergency brake wire, I forget the color. This is all you have to do.
Feb 01, 2009 | Lanzar (SVD59EL) DVD/VCD/CD/WMA/MP3 Player...
Need color codes of speaker connections,power connections etc...
Hi and welcome to FixYa,
Offhand. almost all Pioneer units follow the ISO standards for color coding their wires. Pls reference below:
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 15, 2008 | Pioneer DEH-1800 CD Player
Lanzar model SD43MU(( dvd/cd player wont work not funtions for that wont even appear?
I have a similar Lanzar unit. I had it in twice while it was under warentee for the same issue. I also had it in a couple more times for other issues. It cost me about $30 shipping both ways each time I returened it. About a month after the warentee expired, the DVD quit ejecting again.
Bottom line, I would look at purchasing a different uint or use an ipod instead of the CD.
Mar 01, 2008 | Lanzar SVD26MUT Car DVD Player
Wireing harness.
Hi diamante,
For your reference, pls see below image.
Further, here is a page of the official Clarion standard wirings and their color codes.
Here is a source of the connector for your reference. You don’t need the speaker connector since your unit does not have any built-in amps.
Additionally, if your vehicle’s wiring connections are not of the ISO-standard type or if you just want to verify, please follow this link for the installation adapters you may need to fit your Clarion DRX-9675Z CD Player to your particular vehicle.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 15, 2007 | Clarion DRX-9675Z CD Player
Wire harnest order
Most of current AIWA in-dash units are ISO/DIN compliant and therefore conform to the ISO Wire Color Code standard. If your model is ISO certified then it would be following the below illustrated wiring scheme.
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
If you suspect any deviation, perhaps you are better off purchasing an original Aiwa two, eight way plugs for your CDC-MP32 CD Player.
Hope this be of some help/idea. Post back how things are or should you need additional information.
Nov 04, 2007 | Aiwa CDC-MP32 CD Player
No Power At All
I have the same problem with my sometimes. Sometimes it is working fine and when I turn the car back on, it won't go at all. On the back of the head unit, there is a reset button. Press the reset button then press the power button and it should work.
Oct 14, 2007 | Lanzar VBD1200 CD Player
How to detach face of lanzar stereo?
Here is a link to the owner's manual: http://www.lanzar.com/manuals/VBD1700MP.pdf (Note that the "DCP release button" is the upper-leftmost button on the unit.) On page E-5, it says: 2.DETACHABLE CONTROL PANEL (D.C.P.) Removing The Detachable Control Panel (D.C.P.). 1. Turn the power off 2. Press the D.C.P. release button 3. Remove the D.C.P. Attaching the DCP CAUTION 1. Attach the panel at the right side first, with point B on the main unit touching point A on the D.C.P. (As shown on the digram). 2. Then press the left side of D.C.P. onto the main unit until a ?click? sound is heard. DO NOT insert the D.C.P from the left side. Doing so may damage it. The D.C.P can easily be damaged by shocks. After removing it, place it in a protective case and be careful not to drop it or subject it to strong shocks. When the release button is pressed and the D.C.P is unlocked, the car's vibrations may cause it to fall. To prevent damage to the D.C.P, always store it in a protective case after detaching it. The rear connector that connects the main unit and the D.C.P is an extremely important part. Be careful not to damage it by pressing on it with fingernails, pens, screwdrivers, etc. Note: If the D.C.P is dirty, wipe off the dirt with soft, dry cloth only. And use a cotton swab soaked in isopropyl alcohol to clean the socket on the Socket back of the D.C.P.
Feb 16, 2007 | Lanzar VBD2200MP3 Motorized Slide Down...
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
