Question about Dell OptiPlex Computers & Internet
At boot up my dell gx280 shows the dell boot screen slide to the left about half, then the xp screen is the same. the machine displays fine after that
pgh_pa_guy
  • 2992 Answers
SOURCE: Dell Optiplex GX280 boot problem
I just repaired two Gateway systems with similar behavior (turn on power, fan runs at full speed, no boot), and both needed replacement system boards. (These were a different model, but the symptoms are typical of a dead system board.) I got the boards from a company called Blue Raven Technology (www.blueraven.com).
Before deciding the main board is bad, try another power supply to make sure that's not the problem. Also you might try clearing the CMOS memory on the system board (either by moving a jumper usually found near the backup battery, or by removing the battery itself). Sometimes corrupted CMOS data will keep the system from booting.
Posted on Nov 16, 2008
  • 565 Answers
SOURCE: can't boot my Dell Optiplex GX280 from the
u need to use the sata drive floppyor windows xp corporate with sata drivers. can download from torrents.
If helped rate fixya
Posted on Mar 07, 2009
SOURCE: Dell GX280
Same problem... orange power light, fan starts slow and builds up to very high speed.
I removed my video card and SIMMs --> it beeped on boot and the fan did not speed up.
Put one SIMM back in --> booted fine, pressed F2 to view BIOS. Memory reported fine.
Put all SIMMs back in --> all fine now.
Posted on Mar 17, 2009
siawolf
  • 749 Answers
SOURCE: dell optiplex gx280 won't boot up
you either have the boot priority in the bios off or you have improperly cabled your hard drive . perhaps you set it to boot to cd while installing the operating system and forgot to change the order back.
The floppy drive does not have to be present for the system to boot (if set to "not installed" in bios)
your boot devices are your cd/dvd rom and your harddrive.
Seeing as you've recently replaced the power supply , ime assuming you didnt dismantle the whole computer , just the power leads coming from the power supply, which means you only moved power , not data cables.
This would be the first thing to check -- power to the harddrive and cd rom, the 4 pin connector that sometimes connects to the motherboard and any data cables you might have bumped while changing the power cables. check these things and post here again.
Regards
Posted on Apr 01, 2009
  • 8 Answers
SOURCE: dell optiplex gx280 makes loud fan sound at
You may have a problem with your power supply(the loud fan noise) and eventually it may get too hot and will cause problems like not fully booting.
Posted on Jun 12, 2009
My dell optiplex will boot and says enter system password and i try to type it in but it dosent show words not even dots its a dell optiplex gx280
you are probably using a usb keyboard....plug in the ps2 keyboard(the round one) and it will pick it up.Some wont have the correct drivers for theafterhourspc_1.jpg usb until it boots. PS2 LOOKS LIKE THE ONE ON THE LEFT AND USB IS ON THE RIGHT.
May 28, 2011 | Dell OptiPlex GX280 PC Desktop
Hi my computer dell gx280 didn't work. It keep show "no boot device available". i try to replace with new hard drive but it still show same thing. Can you help me figure out what is problem with it please?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Try the above solution and let me know how you get on?
Jul 04, 2010 | Dell OptiPlex GX280 PC Desktop
Upon booting, i get dos prompt, doesn't do anything further
No compatibility problem in your case. XP should work well with Dell optiplex gx280. Try re-installing the OS, there is problem with the OS version you had used to install.Rate me if it is useful!!
Aug 19, 2009 | Dell Optiplex GX280 (99301) Motherboard
Dell Optiplex GX280 - On power ON , no Fan movement no display
Confirm no leaking or bulging capacitors on your mothboard.
refer to here
http://en.wikipedia.org/wiki/Capacitor_plague
As this was a common problem with the GX280.
If found, you will need to replace the capacitors.
The other check is to make sure the heatsink is fitted correctly, perhaps reaply the thermal paste if you have any. I know that high temps would switch the GX280 off.
Jul 15, 2009 | Dell Optiplex GX280 (99301) Motherboard
Unmountable boot volume or do I need another hard drive ?
Start machine press F8 repeatedly
If it lets you into Safe Mode then go to Programs, Accesories, System Tools, System Restore and try to roll the machine back a week or so
If that does not work you need to find a buddy with a copy of the software and reinstall providing your machine has the Windows sticker on the back or sides giving you the key code
May 23, 2009 | Dell OptiPlex GX280 PC Desktop
Computer saying error loading operating system
You can configure your boot setup from your bios screen (for dell, either F11 or F12) then set up your optical drive as your 1st priority then, save settings. After that, you need to insert your windows XP cd in order for it to boot.
inform me of what happened after you have done this.
Mar 16, 2009 | Famous Brand Dell Optiplex GX280 Intel...
Can't boot my Dell Optiplex GX280 from the
Hi there
hey if you boot into bios and you need to make sure that the computer will recognize the hard drive and that the jumper that is on the hard drive is set as either master or slave depending on what you want than make sure that of the parameters are right and apply it. than restart the computer and than see if the cd will now boot and you should be able to continue from here ok
best regards mike
Mar 07, 2009 | Dell OptiPlex GX280 PC Desktop
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Dell GX280
Dec 01, 2008 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
