Question about Insignia Infocast Chumby
Insignia tablet shows a battery icon when plugged in
My Tablet is on charge and the screen icon shows it is charging but the Charge % Icon is staying the same
Try a different battery charger.
Maybe you are using a battery charger of a phone.
They have the same plug but different Amperage.
Usually tablets have more powerful battery charger than phones (2.1A instead of 0.5/1A).
The battery charger that you are currently using seems to have enough power just to keep your tablet alive, but not enough to charge it.
You can check on the data written on the battery charger's body the maximum amperage.
Jul 16, 2016 | Amazon Kindle Fire HDX 7
Will not turn on
If it is not down to a dead battery, (many batteries show that they charge full but they cannot hold that charge so they no longer switch on,) I would search on line for a method to hard reset the device. Remember that if you do go down that road you may lose any data stored on your device.
Try the battery first.
GOOD LUCK CARLOS
Nov 05, 2015 | Insignia - Flex 10.1" Tablet with 16GB...
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
May 11, 2015 | Tablets & eReaders
How do I remove padlock icon from the WIFI connection site.?
If you enter the correct pass code for that "site" What you call a site is a wifi router or hotspot. When you own one and did set it up, you should look in the manual, what code you gave it.
Apr 28, 2014 | Insignia - Flex 8 inch Tablet with 8GB...
The camera viewfinder faces the user. how can I take pictures?
If you press and hold on the screen or touch the settings icon on the right side you should see a settings menu come up.
There may be a sub-menu for camera settings you will need to enter, but the rotate icon should be there.
Apr 08, 2014 | Insignia - Flex 8 inch Tablet with 8GB...
Hi, I charge my samsung tablet, may or may not use it. the battery icon does not show correctly. some times it says that "charge the battery" but i leave it aside and after for example one hour i check the...
You are likely running an old version of the firmware / ROM. See if Samsung has a new version, or if you are comfortable with rooting visit XDA Developers forums to learn how to get a newer version with more up to date power management and battery conditioning updates.
Dec 04, 2013 | Samsung Galaxy Tab Tablet PC
Tablet froze and now doesnt restart
Leave your tablet charging for a hour minimum. The battery might be so dead it has no power to start up at all. You get in to recovery mode do restore to factory settings.
Jun 02, 2013 | Coby Kyros 716829701508 Tablet PC
Insignia flex tablet will not turn on
Make sure the battery is fully charged and left plugged in while you try to turn on the tablet.
Hold down the power button (it takes a long press) until you see the INSIGNIA logo on the screen.
If it takes longer than 10 seconds and the unit hasn't turned on, the unit is not functioning properly.
If you have the protection plan, I would recomend you return it to Best Buy for a new one.
Jan 16, 2013 | Insignia Tablets & eReaders
Insignia Infocast Chumby Logo
74 people viewed this question
Top Insignia Tablets & eReaders Experts
WTF Chuck.....
WTF Chuck.....
Fred Sops
Donald Gunn
Level 1 Expert
Are you an Insignia Tablet and eReader Expert? Answer questions, earn points and help others
