Question about Car Audio & Video
Metra ddxl6511 Reset radio
How do i reset the airbag light on my Cadillac STS.
Requires Requires a scan tool with airbag capabilities. However if the fault that caused the light initially is corrected it should reset iyself. If the fault still exists the light will come right back on.
Nov 15, 2015 | Metra 2007-2008 Cadillac Escalade Ext...
How to reset the service engine lite for a mass air flow sensor
It can be reset by a code reader or autozone, dealership, any car repair garage.
Apr 01, 2014 | Metra 72-4568 2005 - 2008 BUICK LACROSSE...
How do i replace my stock radio for a after market radio in a 1995 lexus sc400
There are several steps:
1. Take out the center cup-holder (it pops out with a little tug upward). unscrew the 2 screws.
2. On the shifter (lower part) there is a cover that covers 2 screws, unscrew and remove the shifter knob.
3.Take a pick tool and lift the shifter bezel console (black) it also pops up.. there are 3 or 4 connecters (disconnect with a small flat head screwdriver)
4. Once the shift cover is removed, there are several screws and tabs holding the bezel trim down unscrew the screws and lift bezel trim up,
5. Disconnect the ash-tray (blue connector)
6. Disconnect the hazard signal control , volume control connector and the climate control connector.( On the left side)
7. There are 4 screws holding the the radio and climate unit cage to the dash frame. (unscrew)
8. Now it gets a little tight, pull the unit towards you slightly and disconnect to connectors for the climate control unit (on top) and the factroy radio (on the bottom).
9. Next remove the radio and climate control unit from the cage(screws on the sides).
10. Next you will need a new cage: Metra 95-8157B Double DIN Installation Kit for 1992-2000 Lexus SC300 and SC400 (Black)
by Metra Link: http://amzn.com/B001TJG7SA
11. You will need the following harness: Metra 70-8112 Radio Wiring Harness for Toyota Amp Integration 15 Pin by Metra
Link: http://amzn.com/B0002BEUBW and/or Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker by Metra Link: http://amzn.com/B0002BEQJ8
12. Match the wires according to the metra kit and new radio instructions.
13. Next follow instructions in reverse for re-stall. GL.
Feb 09, 2014 | 1995 Lexus Sc 400
Aquatronics Radio MS1550G 4X40W
I have an Aquatronics MS1550G radio on my 2006 Suntracker. The radio speakers have sound, but the sound is barely audible. I have used the reset button with no success. Is there a quick fix to this problems?
Aug 08, 2009 | Aquatronics Car Audio & Video
I bought Metra Ltd 70-7001 adapter for my Mitsubishi galant of 2000 !i connected the adapter to my new JVC KDR-200 CD Receiver ! the radio turns on and i can go to the menu and all that but i cant hear any...
Hello jozeffushe,
First check all of the connections between your receiver harness and the Metra. The colors should match up. Then check each wire from the Metra harness to your vehicle wiring against the vehicle color code found here. If everything checks out, try resetting the receiver. Remove the faceplate (press the button at the lower left) and starting with the left side, gently pull the faceplace off. Now, using a ballpoint pen or similar object, press the reset button (Just left of the right edge near the bottom is a small hole with the reset button behind it.) for 1-2 seconds.
If this fails and you still have no sound, I'd suspect that the receiver is defective.
Hope this helps. If it does, please rate as "Fixya".
Jul 06, 2009 | Mitsubishi Metra Ltd 70-7001 95 Vehicle...
Toyota original car audio 75400
You can pick up a Metra reverse harness from most stereo shopes and it will also have the wiring info you need.
Jun 04, 2009 | Metra Toyota Car 1987 2000 *Nic
Radio plugs were cut
you will need to get a chilton or hays repair manual (ore refer to METRA for color code harness) METRA sells aftermarket to factory conversion harness. you can cut one up and make it work. The manuals should have the full electrical diagrams with colors explained.
Apr 28, 2009 | Car Audio & Video
Factory Amp
I assume you used the correct Metra plug (70-1878) to install the radio. Ensure the blue and white wire on the Metra is attached to the blue and white wire (or solid blue) on the Sony. This will provide + turn on voltage to the factory amp.
The other good possibility is that the Metra harness has a black and a black and white set of wires both must be ground.
Lastly the Metra harness does not provide these( -) grounds, they are supplied by the braided strap . or the single wire that was attached to the back of the Jeep radio.
Jul 22, 2008 | Infinity 475A Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
