Question about Car Audio & Video
Daewoo hi power 35wx4ch code - Car Audio & Video
Code for daewoo tv
hi,
You didn't mentioned any thing about the brand and model number of the remote you have. Need the same to give you code for Daewoo tv
ok
Aug 13, 2011 | Televison & Video
Hi My Name is Yessy, I removed my battery from my 2002 Daewoo Leganza.. And now my Car Radio doesnt work & its asking for a four digit Code!!
hi yessy your car have a radio code its mean anti theaf system.now you should need a help from your nearest daewoo dealer.they need your vin number to found your securety code ok
Jul 13, 2011 | 2002 Daewoo Leganza
My car radio won't come on.
hi
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
hi please check the above mentioned wires are in place. if all in place then check weather power is coming to these lines. if power is also coming the problem lies with the system itself. please service it and it wil be ok.
if the information was usefull then vote me
Jul 12, 2010 | 2000 Daewoo Leganza
Need the code for a Daewoo TV
Hi, It should be one of these.
0451 0019 0092 0623
Oct 11, 2009 | Daewoo DTQ-20U4SC 20" TV
I want code this daewoo
The radio code feature of Daewoo models (sold in the US from 1998 - 2001 as Leganza, Nubira, and Lanos) is meant to be an anti-theft security feature, but unfortunately it can also present a problem to legimate owners when their car batteries have died or been replaced. When the radio is removed from the power source (or the power source is interrupted), the radio will reset itself (prevent any use) and flash "CODE" until the proper code is entered.
Each radio has a specific four-digit code, which was originally provided on a plastic card within the owner's manual kit. New owners were encouraged to remove the card and keep in a safe place outside the car (eg home). Since these cards may be lost over time (or perhaps not passed along when the car was sold used), that leaves today's owner in a tough spot.
To obtain your code... You can try calling Daewoo Motor America (the company still operates a HQ in CA for service/parts/warranty purposes); their website is still www.daewoous.com. You can also try calling your original Daewoo dealer, who hopefully still has some technical materials and personnel to help you identify your unique code. Some General Motors dealers may be able to help, as GM acquired Daewoo and still sells Daewoo-made cars in the US under their Pontiac and Chevy brands. But all methods above may be difficult for an individual detailed problem such as obtaining your unique radio code.
If all else fails, TRY THE CODES BELOW, which were the most common codes used in models during the 1998-2001 model years.
4316
2152
4513
4362
1156
2145
3451
6361
5624
5241
3346
1165
3241
4524
5436
I am posting these because - although the code feature was a valuable anti-theft feature - there have been no models sold in the US since late 2001, and the radios are now undoubtly worthless to theives. At this point, the radio code feature can only be a major nusance to an owner of a still-running used Daewoo. Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 19, 2009 | 2001 Daewoo Lanos
Hi can someone please help me fine a radio code unlock for a 2001 daewoo leganza.
Pull off the trim around the radio and look in on top of the radio. I have found Daewoo radio codes stamped on a tag on top of the radio.
May 12, 2009 | 2001 Daewoo Leganza
I need code for daewoo cd cassette player
i need code for cassette car Daewoo Matiz
Aug 16, 2008 | Car Audio & Video
Remote code for TruTech dw19tt
TruTech is made by Daewoo. I entered Daewoo codes from my digital converter box list. The sixth code I tried made it work (140 for an RCA converter box). Now the Converter box remote will control volume and power on my Trutech DW19. Regards, tmjl.....
Jun 09, 2008 | Televison & Video
Daewoo tv/vcr combo ccodes
Hi here are some codes I have 0278 0624 If they dont work try programing the VCR
first then the TV. To program the VCR put a tape in and put it on play after you put
the code in hit the power button the vcr should stop playing. If that works then program the TV.
Some TV/VCR combo's require two codes. Good Luck
Mar 02, 2008 | Daewoo DVQ9H1FC 9 in. TV/VCR Combo
Washe machine problem
The sound become beet? We need a little more detail. Look in the owner's manual and tell us what is error e9.
Feb 26, 2007 | Daewoo DW500M Top Load Washer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
