Question about Trekstor MovieStation Computers & Internet
Trekstor hard drive dsmmu p in a
Drive has a clicking sound and is not recognized by my computer
2 Suggested Answers
computus
  • 487 Answers
SOURCE: Just need to ask, trekstor external HD light is
Hi, unfortunately your are probably right. You can buy a new hard drive and install your self as the cheepest option?
Posted on Jul 10, 2010
Why can't my win. 7 computer recognize my TrekStor 250G external drive?
it might be that the external drive has failed . have had 3 so far that did.
Jan 24, 2015 | Trekstor Computers & Internet
Trekstor model dsmmu p a has a clicking sound and data can not be read by computer
The sound you are hearing is known as the click of death. The hard drive is no longer any good.
Feb 12, 2014 | Trekstor Computers & Internet
My tredstor external hard drive dsmmu-p-in-a all of a sudden asks if I wants to merge the files (on my computer hard drive) with the previously saved files on my trekstor (of the same name). It hasn't...
OK hello I'm new to the tech support any way how much memory on the Hard drive and much is left on the external drive it may ask you to merge to tell you you need room for all files and that you may have almost reached the compasity on the drive
Mar 12, 2017 | Trekstor Computers & Internet
Hi there, my TrekStor external HD model
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program called asoftech data recovery to recover your files.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 05, 2011 | Delta & Single Handle Shower Faucet
Neither my pc nor my tv don't recognize my Trekstore MovieStation Maxi t.u 1000 GB, what should I do?
this could be a driver issue
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
Jun 07, 2011 | Trekstor 88550 MovieStation maxi t.u 500GB...
I have a trekstor hard disk ,model number-MSMTU EM s 8,and it is not getting recognized by computer
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 14, 2011 | Trekstor 88570 MovieStation maxi t.u 1TB...
My lapto cannot see the Trekstor external hard disk. no letter assigned.
Right click My Computer. Click Manage, Then Disk Management, See if the drive is there, if it is right click it and change drive letter.
Apr 06, 2011 | Trekstor Computers & Internet
Jul 10, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Drive Being Recognized as Removable Disk
Use EASEUS Data Recovery Wizard to recover the data. You can find the program on the internet..
To format afterwards click Start, click Run and type compmgmt.msc.. In there format your drive..
Mar 10, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Trekstor Storage device
I have an answer on how to fix the Trekstor Datastation "Removable Disk" problem.
I also own a Trekstor Datastation 500GB and had the same problem even though it worked for several months then all of a sudden when I tried to hook it up to another computer, it stopped working. It would recognize the USB connection but you could not read the drive as it would say "Removable Disk".
In "Device Manager" it recognizes the drive as Sundata USB2SATA. But what it really should be is "WDC WD50 00AAVS-32ZTB0 USB Device" or something similar to that. For those that are wondering, yes, the hard drive is a Western Digital Hard Drive. Western Digital Caviar to be exact.
Solution: You need to open the cover to the hard drive and reconnect the hard drive to the connector on the board. It's that simple!
It is very loose and this model is not well designed so it can easily come off if you accidentally knock over your hard drive or move it to another location. The hard drive is held in place by screws on a holder where there is room for the screws to slide if the screws are not tight enough.
You'll need a T10 screwdriver bit to remove the cover and a Phillips screwdriver to adjust the hard drive.
NOTE: Doing this will probably voids your warranty but trust me, it works and it's really easy and quick to do. Took me 15 minutes.
May 03, 2008 | Trekstor Datastation maxi t.u SATA 500 GB...
Computers & Internet Logo
47 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
vojvodabudva
Mohamed Ismail
Mohamed Ismail
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
