Question about Bosch SHY56A02 / SHY56A06 Built-in Dishwasher
Runs to 1 minute and then continues to run indefinitely
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
My furnace fires up run for about five minutes then fire box shuts off and the fan runs until my furnace runs through its cycles but the fan runs almost continually runs it only shuts done for a few...
On a conventional furnace of today, your furnace may have a flame sensor which is typically located in front of an end burner opposite the ignitor. It is connected by 1 wire. This metal rod needs to be removed by 1/4'' screw in most cases and cleaned. Clean with steel wool or even a clean greenie scrubber will work. Wipe clean and re install. Many problems can cause these symptoms, but this is a very common one.
Mar 02, 2015 | Heating & Cooling
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
I need the full factory reset procedure for my HP OfficeJet Pro 8500 A909N
Hi! this is Alex Walker call me +1(518)348-9393 i am expert to help you for this issue thank you
Aug 10, 2017 | Office Equipment & Supplies
The mercedes E230 1996 fan does not go off when engine is off
A lot of cars cooling fans will continue to run after the engine is shut off until it has cooled down to a specific temperature. Does yours eventually go off or will it stay on indefinitely until it runs the battery down? If it never goes off you could either have a faulty coolant temperature sensor or there could be a short to ground in the wiring somewhere.
May 25, 2011 | 1997 Mercedes-Benz E-Class
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
The unit cycles every minute and the fan continues to run.
you are right the problem is with the thermostat. if this is an all-in-one unit there is a wire that runs from the thermostat to the front of the evaporator coil where the air returns to the system to be cooled. you can try to move the wire further away from the coils and see if it prevents the unit from short-cycling. btw it's not very good for the unit to do what its doing now, as i'm sure you could imagine. if its a separate thermostat i.e. one that runs on 24V and has wires running to the a/c, then just replace it with one from Home Depot and you should be good to go. if it's other than 24V then you will likely have to get a replacement thru the a/c's manufacturer.
Jun 16, 2009 | Dometic Rooftop RV Air Conditioner
Fan runs indefinitely after heat shuts off
yes I have replaced a couple of t-stats lately (honeywell)
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Bosch SHY56A02 / SHY56A06 Built-in Dishwasher Logo
23 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
