Question about Motorola Mobility 1 Premium Clear Screen Protector Droid Xyboard 10.1 Tablet Accessory
Motorola xy board 10.1 screen froze and locked
Screen frozen turn off and on. does not respond to touch. turn on for few seconds and turns off
Paper white will not respond to touch.
always like to refer to Amazon help whenever possible. I copied their directions for this. Even if your's is not 5th gen it will work. You can also check specific info for your model by logging into Amazon.com Click help, then device help, click on you device and look through the info available.
Many issues with your Kindle, such as a frozen screen or issues with downloading content, can be solved by restarting your device. Help for Kindle Paperwhite (5th Generation).
Press and hold the Power button for seven seconds until the Power dialog box appears, and then tap Restart. Note: If the Power dialog box doesn't appear, press and hold the Power button for a full 40 seconds until your device restarts.
Nov 29, 2016 | Amazon Kindle Paperwhite
Kindle Fire has frozen
Lots of help and videos Joan.
  • Amazon.com Help: Quick Fix: Slow or Frozen Screen www.amazon.com > Amazon Device Support Quick Fix: Slow or Frozen Screen. If your Fire tablet or Kindle e-reader screen is slow to respond or freezes, restart your device or try the troubleshooting steps below.
  • Amazon.com: Customer Discussions: my kindle fire has frozen www.amazon.com/forum/kindle?cdForum=Fx1D7SY3BVSESG&cdThread=Tx30... A discussion in the Kindle forum. Amazon Try Prime All Go. Shop by Department ...
  • What to Do If Your Kindle Fire Screen is Frozen or Locked ... https://www.supportrix.com/kb/what-to-do-if-your-kindle-fire... Kindle Fire is a tablet computer released by Amazon, which features a full color 7-inch display with multi-touch. In addition to surfing the Internet, this multimedia ...
  • Amazon.ca Help: Troubleshooting Your Kindle www.amazon.ca/gp/help/customer/display.html?nodeId=200829000 Quick Fix: Slow or Frozen Screen. If your Fire or Kindle screen is slow to respond or freezes, restart your device or try the troubleshooting steps below.
  • Frozen or Stuck Kindle Fire - YouTube www.youtube.com/watch?v=X9iffkiMDB8
    • BY RC JR
    • 5 MIN
    • 100K VIEWS
    2014-05-15 · Is the touch screen being unresponsive? Amazon Kindle Fire Locking Up/Freezing? This quick little video will show you how to do a quick fix. ...
  • How to Fix a Frozen or Unresponsive Kindle ' The eBook ... blog.the-ebook-reader.com/2014/...fix-a-frozen-or-unresponsive-kindle How to Fix a Frozen or Unresponsive Kindle. ... If your Kindle Fire HDX or other Kindle Fire tablet is suddenly ... my kindle has frozen on page one of four for at ...
  • My Fire is frozen up. - Kindle Fire - iFixit https://www.ifixit.com/Answers/View/85362/My+Fire+is+frozen+up. jojack6200, try this "Performing a hard reset on your Kindle Fire may resolve intermittent issues like a frozen screen, battery issues or trouble downloading content ...
  • Why has my Kindle frozen? - Telegraph www.telegraph.co.uk/.../advice/9590203/Why-has-my-Kindle-frozen.html 2012-10-07 · Help, my Kindle has frozen. The only thing on the screen is an etching of Hercules, with a black section at the bottom. I can't switch it on or off, charge ...
  • What to Do If Kindle Is Frozen & Will Not Turn Off or On ... https://techwalla.com/content/do-frozen-not-turn-off What to Do If Kindle Is Frozen & Will Not Turn Off or On? ... If the Kindle does not have enough ... If your Kindle remains frozen after charging the battery and ...
  • How to Reset a Kindle (with Pictures) - wikiHow www.wikihow.com/Reset-a-Kindle
    • 1.8M VIEWS
    2016-03-03 · How to Reset a Kindle. If your Kindle becomes unresponsive or begins to have frequent problems, you can troubleshoot it by trying a reset. A standard, soft ...
  • Apr 20, 2016 | Amazon Kindle Fire HD
    I have a Samsung tablet 3 that the touch screen is frozen. I see where ppl are saying to turn off power, hold vol. down & power to get in reboot mode. I can't get mine to power off (touch screen froze) &...
    Seems like the digitizer isn't working anymore u may wanna get ur tablet examined but to quickly turn off some tablets is to press and hold the power key till it shuts off and not lock the screen
    Oct 21, 2014 | Tablets & eReaders
    How do I turn off my tablet when it is frozen and buzzing?
    On most modern computer devices, just pushing the On/Off switch is only a suggestion and the computer can ignore it (or might not get the suggestion). Try holding the On/Off switch down until the computer turns off (that might take 5-10 seconds).
    May 13, 2014 | Nextbook Premium 7 Capacitive Touch...
    Frozen page in an E book novel. Can't go forward or backward. Everything else works. I can return to home screen but not to library. Touch does not respond on the page which froze. Thanks
    There usually is a reset pinhole where a straightened paper clip can be inserted to press an internal switch. this hole is usually on the edge. press and hold the switch for up to 10 seconds lightly. then the ereader should restart
    Mar 12, 2014 | DBPOWER for Apple iPad 2, iPad 3, and iPad...
    Surface tablet froze while using and nothing works won't power off or anything
    Hold the power button down for 10 seconds. Then turn it back on.
    Feb 28, 2014 | Microsoft Surface RT
    Screen is frozen at enter pass code screen,and touch screen not responding
    click the lock button again, and plug it up, and wait for it to respond
    Oct 16, 2013 | Amazon Kindle 1
    Screen is frozen
    Couldn't even turn mine off ... researched this.
    SIMPLE SOLUTION: Hold the power button down for more than ten (10) seconds. WORKED!!!!
    No longer frozen.
    Mar 09, 2013 | Samsung Galaxy Tab Tablet PC
    Screen is frozen and won't respond to touch or turn off
    Hold the power button down for up to 15 seconds or until the screen turns off. This is considered a hard reset on most tablets.
    Nov 27, 2012 | PANDIGITAL SuperNova
    Motorola Mobility 1 Premium Clear Screen Protector Droid Xyboard 10.1 Tablet Accessory Logo
    13 people viewed this question
    Top Motorola Mobility Tablets & eReaders Experts
    Are you a Motorola Mobility Tablet and eReader Expert? Answer questions, earn points and help others
