Question about Facebook Apps
Fitbit troubleshooting i cannot get my fitbit dashboard to upload a photograph in the profile section. Just sits - doesn't do anything. I have followed all instructions but no luck. I put in trouble issue and no response for over a month. Is there a "person" to talk with? Help!
SOURCE: Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Posted on Oct 02, 2008
  • 7 Answers
SOURCE: kodak 3250 printer (brand new) wont scan, issues
From Kodak's website:
Answer : To resolve error code 2005, 2006, 2007, 2008, 2009, 2036, 2105, or 2106:
1. Go to www.kodak.com/go/2005 to run SSEUtility.exe.
2. Do one of the following depending on your browser:
- WINDOWS Internet Explorer: Click Run, then click Fix.
- MOZILLA Firefox: Click Save, then double-click SSEUtility.exe.
3. Try to install the KODAK All-in-One Printer Software.
4. If the following message window appears, your processor supports SSE and the utility will not be able to help.
Click the X in the upper-right corner to close window.
5. If the problem continues or you were not able to use the utility, contact Kodak (1-800-421-6699)
Posted on May 04, 2010
  • 11967 Answers
SOURCE: Nikon D90. Uploading photographs to PC I notice
If this bothers you, why not do what the pros do...use a card reader to transfer the pics.
Posted on May 31, 2010
  • 77 Answers
SOURCE: I am having trouble in installing my audio driver
check device manager may be the device is disabled otherwise you are trying a wrong driver.
or
for some audio drivers u have to run universal audio architecture from microsoft. i think this is your problem. download microsoft universal audio architecture and install that after that install audio driver.
Before that check device manager for device enabled or disabled?
Posted on Jun 18, 2010
TOLhamRadio
  • 509 Answers
SOURCE: I have an XM roady
Go outside with the unit in the clear, and If it says "Antenna" - it means the connector for the antenna, the docking base or the antenna itself it usually bad. See if you can borrow a buddy's antenna just to see if the "Antenna" warning goes away. It could be the antenna & its connector, could be the docking base (make sure the radio is plugged in tight) or could be the radio (but usually isn't). Good luck and let me know what you find out.
Posted on Nov 09, 2010
I can't find my instructions. how do I correct the time on my fitbit charge?
    1. Editing your timezone settings
      1. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard.
      2. Choose Settings > Personal Info and find the Time section.
      3. Choose your timezone and select your 12-hour or 24-hour display preference.
      More items...
      Help article: How do I update my Fitbit settings? - Fitbit Help
      https://help.fitbit.com/articles/en.../How-do-I-update-my-Fitbit-settings Fitbit
    Feedback
  1. The time is incorrect on my tracker's display - Fitbit Help
    https://help.fitbit.com/.../The-time-is-incorrect-on-my-tracker-s-disp...
    Fitbit
Jan 03, 2016 | Fitbit Charge Wireless Activity Tracker...
The time on my fitbit is incorrect. How do I correct. Currently it registers 9:43, but, I'm on Eastern Standard Time.
    1. Editing your timezone settings. Log into your dashboard at fitbit.com and click the gear icon in the upper right corner of your dashboard. Choose Settings > Personal Info and find the Time section. Choose your timezone and select your 12-hour or 24-hour display preference.Mar 10, 2015
    Feedback
Jan 03, 2016 | Exercise & Fitness
How to set time on fitbit?
Dec 02, 2015 | Exercise & Fitness
How to set time on my fitbit
    Once you sync you should see the correct time.
Jul 07, 2015 | Fitbit Flex Wireless Activity & Sleep...
How do I delete my info form the FitBit flex? I want to return my new flex to buy a FitBit Surge.
HOW DO I DELETE PROFILE DATA FROM MY TRACKER? Fitbit uses your height, weight, and age measurements to properly calculate your stride length (which helps determine your distance), calorie burn, and active minutes.
To delete your profile measurements from your tracker, the tracker must be set up to a different account. Once a tracker is set up to a different account, it will automatically unlink itself from the dashboard and all of the tracker's stored data will be permanently deleted from the tracker. You can find instructions on how to create a new account in the following articles:
May 14, 2015 | Fitbit Flex Wireless Activity & Sleep...
My battery is charged but showing empty on computer. I restarted it but still showing empty.
with computer turned off take out battery and wipe off contacts then reinstall battery. If it is still empty after letting it sit a bit to see if it is charging you either have a bad battery or the charger in the computer is bad . that is an expensive fix. usually not worth the money unless you have an expensive computer and then that probably would not happen.
May 07, 2015 | Fitbit Flex Wireless Activity & Sleep...
How do I put a profile picture on fitbit
1) Login to your account at www.fitbit.com
2) Click the little circle picture of the generic face toward the top right
3) Click 'Change profile pic' under the existing picture
Jan 21, 2015 | Zippy Computers & Internet
How do i transfer pictures from computer files to facebook
login to your facebook account.. And click on profile.. Your profile is displayed, now click on your profile pix or avatar.. The option to upload is displayed now.. click on the space provided .. Tru dis you can browse files on your computer..pick any pix you want and click upload .. You can as well create album for multiple pix upload..
Jul 21, 2011 | Facebook Social Network
How do i scan my photo to my face book page with a seperate camera
Take a photograph
Connect your camera to your computer and download the photographs you clicked.
Choose the photograh that you wanted to upload the copy it to the desktop.
Then go to the profile page of your facebook account and you will be able to upload the photograph.
Dec 25, 2010 | Epson CX8400 All-In-One InkJet Printer
Facebook Apps Logo
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
