Question about Frigidaire Dehumidifiers
BLOWER WHEEL BROKEN
Blades on blower wheel are broken off, need to replace the blower wheel.
  • Frigidaire Master
  • 3,382 Answers
In your instruction manual you should find a parts list, purchase a new blower wheel and install it. If it is an older unit it may be best to just replace it.
Posted on May 01, 2014
2 Suggested Answers
  • 18 Answers
SOURCE: can a fix a cracked blower wheel for my dryer with
sorry to say dont do it if you were able to find that your very capable of replacing it good luck
Posted on Jul 19, 2009
Why does blower wheel stop on Frigidaire dehumdifier?
Good Afternoon Desi,
I understand that the blower wheel is not spinning on your Frigidaire dehumidifier, model# FAD504DUD. I also see that the compressor will stay on unless the dehumidifier is unplugged. I suggest you contact the manufacturer for further assistance. They can possibly clarify why the compressor stays on and why the blower fan is not working. If not, they should at least be able to point you in the right direction of having your dehumidifier working. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire FAD504DUD White Energy Star 50...
Caster broken
Some caster wheels are a press fit on an axle. That's why they frequently fall off.
Feb 19, 2014 | Goldstar DH304 Dehumidifier
BLOWER WHEEL BROKEN
older model- might not be able to get a replacement. try appliancepartspros.com
Feb 12, 2014 | Frigidaire Dehumidifiers
After 5 years of good operation, it now ices up immediately
If your Indoor Coil is Freezing Up,
You need see if the blower runs if it does, Then shut it off and check your filter, indoor coil and blower wheel, to see if they are dirty, if they are, they need to be cleaned, if not then you are probably low on refrigerant. If the blower doesn’t run when you turn the switch to on then you need to check the blower and capacitor out.
If your not familiar with any of this then you need to call a service tech.
Sep 08, 2009 | Maytag M7DH45B2A Dehumidifier
After about 5 minutes the unit stops working. No sound or even a fan noise. I just cleaned the filter to see if that helps, but it didn't.
Is the fan running and stopping before the unit completely quits?
If the fan quits the compressor won't run very long.
I would start with the fan motor or capacitor.
Shut the power off to the unit, spin the blower wheel to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
r.
Aug 21, 2009 | Dehumidifiers
Ice is forming on the coils - delonghi dehumidifier
Check your filter, indoor coil and blower wheel to see if they are dirty, if they are they need to be cleaned, if not then you are probably low on refrigerant or Blower speed to low. If the blower doesn’t run when you turn the switch to on then you need to check the blower out, especially the capacitor.
Aug 01, 2009 | Dehumidifiers
Can a fix a cracked blower wheel for my dryer with liquid cement or should I get a new one.
Jul 19, 2009 | Comfort-Aire HD-651 Dehumidifier
Dehumidifiers Logo
80 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
