Question about Xerox WorkCentre M-24 Color Copier
Where is the hard drive located on the xerox phaser 3635
How do I pull the hard drive on a Xerox phaser 3635
  • 2072 Answers
SOURCE: xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
Posted on May 20, 2008
nakshatraipu
  • 241 Answers
SOURCE: How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Posted on Feb 11, 2010
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
  • 5 Answers
SOURCE: need xerox phaser 3124 printer driver compatible for mac 10.6
go to www.samsung.com download and install mac driver for ML-2510 works like a charm for xerox phaser 3124
Posted on Jun 22, 2010
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
09-800 on phaser 3635 xerox how to fix
That error indicates an incompatible toner cartridge for that model. Verify you are using oem Xerox toner.
Dec 21, 2015 | Xerox Phaser 3635MFP/X Multifunction...
How do I print labels using the bypass tray on Xerox phaser 3635?
All I can add to your question is from my experience.
Make sure you have the recommended labels installed.
The fuser can cause jams when not using the correct recommended stock.
Very old labels tend to ooze a small amount of glue along the edges and can get stuck to the inside.
Print as you would do on paper, perhaps try printing on some white 80 GSM stock and hold them up to the light to check alignment.
Good luck.
Jul 02, 2014 | Xerox Phaser 3635MFP/X Multifunction...
Where can I buy xerox phaser hard drive
nowadays its hard to get 20gb but you can get 40gb from
http://www.office.xerox.com/product-resources/097S03779/enus.html
Sep 13, 2013 | Xerox new hard drive 20gb internal phaser...
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
Dec 20, 2012 | Xerox Phaser 3635MFP/X Multifunction...
How to reset admin password on phaser 3635
xerox machines come with default passwords.
once that password is changed only the changer knows it.
should he forget or lose the password he flat has a problem.
the reset requires a xerox laptop/tech to reset and they "will bill" you for doing it.
Jul 01, 2011 | Xerox Phaser 3635MFP/X Multifunction...
Xerox phaser 3450 has power but won't boot up - could this be uneconomical to repair?
it could be the hard drive that is messed up. hard drives here in SA cost about 700 bucks brand new IDE
Nov 09, 2009 | Xerox Phaser 3450DN Laser Printer
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
Sep 07, 2007 | Xerox Phaser 8500/DN Printer
Xerox WorkCentre M-24 Color Copier Logo
237 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
