Question about Honeywell Enviracaire Elite F300E-1019 Air Purifier
Water leaking There is water leaking from my system. How can I correct this?
What is the best method for purifying water?
depends on where you are and when you want the water treated.
for camping and hiking , water purification tablets are quick and easy methods and one of the best ( used by the armed forces )
if you want it for home use
running the water through a ceramic filter then through an ultra-violet purifier will get rid of all the bugs
for larger volumes an osmosis purifying system as used by the water treatment works in council water supplies is best
so you need to specific as to when you want the water pure.
boiling water is ineffective as it concentrates the bugs and doesn;t kill them all, however distilling water by boiling off and collecting the steam back to water separates the bugs
Dec 26, 2016 | Air Purifiers
How does one access the drain pan in a Mr. Slim? I think I have stagnant water (minimally), mildew or mold somewhere and nee to make sure.
POUR some strong bleach water in it where you saw the second guy put water in . that should kill any bacteria if there is any
Aug 06, 2015 | Mitsubishi 9000 Btu Mr.slim Ductless Mini...
Why does my water heater over flow when we use too much water?
Over flow? You mean you have a major water leak? I'd call a plumber.
Apr 10, 2015 | Water Heaters
I have an E1 error message on my Idylis 400 square foot air conditioner. There is no water in the system.
Add the water in the system and see what happens, Even a horse needs water to work. I take it your unit is an evaporative A/C. I have a Penguin water assisted A/C, of which I have to fill a large plastic container then load it in the unit and start the A/C. It cools well but doesn't really cool like a wall A/C. But it's better than nothing.
Jun 16, 2014 | Idylis 434 Sq. Ft. 280 CADR Air Purifier...
Water filter
Check to see if you turned on the water to allow water to flow again if thats not it check to see if you put the fillter in the correct way you may have put in upside down. Good luck
Apr 11, 2014 | Manitowoc SY-1204A/B570 Air Cooled 1,205...
Bleeding the radiator
take the top off the header tank ( part you fill the water in) top to the top run engine until it boils or fan kicks in to cool down the engine. while it is heating up squeeze the pipes around the engine to help release the air better DONT put your hands near any moving parts. keep the water full to the top while doing this. when at temp turn off engine and leave to cool down dont add any water or do anything till it has cooled down. when cooled down top up to the mark and should be good then if not then the thermostat may be faulty. or you have a blockage some were in the system that is causing the over boiling problem also check that the fan is working and the temp switch for the fan is working all these can make the engine over heat, also when bleeding the system have the heater on number one and heat on full.
Apr 02, 2014 | Spectre 2001 Chrysler Concorde - 2.7L V6 -...
There are 2 holes on underside of filter housing & when turn on filter water , out both holes, why I hate running it as you don't know if you are getting filtered water from both holes.Help
The main problems I'm seeing on these posts for this filter are design and operater issues. 1. I never run hot water through the unit in filter mode. 2. I never run cold water through the filter turned on high (pressure issues arise), it doesn't filter the water any faster. You just want enough flow to run through the filter. 3. The steel sleeve was a good solution (again pressure) but came up alittle short (ie my epoxy fix). 4. The light is powered by a chip batterey that is unreplaceable and may be bad. Try reinstalling the cartridge. I personally pay no attention to the lights other than a clue. I change my filter when the taste changes or there becomes a flow issue. 5.There are filter screens prior the filter that can become clogged if you live in a poor water area. 6. The filtered water only comes out of the spigot and no other leaks (something loose or pressure issue).
Sep 30, 2013 | PUR (FM-9500) Air Purifier
What can be done to repair a leak from a tiny hole on the bottom of PUR water filter?
I am having the same issue. I've just replaced the filter and it started leaking out of this hole, where it never had before.
I am thinking that maybe the filter isn't seated properly, and that's causing the leak. But I have attached a picture of the hole in question. Any advice would be helpful. Thanks!
Feb 03, 2013 | PUR (FM-9500) Air Purifier
Under Counter Water Filter Leaking after Use Sometimes!
Got it! Your return line is clogged!
I have the same dispenser, and there are 3 tubes attached to it. One of them (black on mine) goes from the faucet to the drain pipe coming down from the sink. That line can get clogged over time with stuff coming out of your sink. You can probably disconnect that line at the drain pipe end and **** oput the connection and as much of the hose as you can get too., Reattach the line and you are done. Fire it up.
On my unit, we hear a dripping sound in the drain when the unit is charging. If you don't hear the dripping sound after using the unit, that line is probably clogged up!
See ya!
Everett
Mar 14, 2008 | Biozone Water Filters for Counter Top:...
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
Honeywell Enviracaire Elite F300E-1019 Air Purifier Logo
35 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
