Question about Tascam Cd-rw900sl Cd Recorder/player
On my CD-RW900-SL I have an error not covered in the owner's manual. When recording optically all of a sudden the recording ends and I get the message "eject error". Also I cannot eject the CDR until I turn the recorder off, and then on again???
2 Suggested Answers
gopakumarg43
  • 75591 Answers
SOURCE: Still waiting for someone to contact me about
Hello
Its system control section does not get power at all. All other sections are working. This is due to a power supply section trouble inside. There is four regulators, fitted on-board, to regulate supply to different sections. Out of which, system control and display section doesn't gets proper voltage, Actually this is not a user repairable fault. A skilled work indeed. The technican must have a sound knoledge in digital electroncie to proceed with service. Just contact any service technician who is experienced in serviceing digital audio equipments. Never touch to system control section, without proper knoledge. Will make the device irrepairable. OK.
Posted on Aug 05, 2011
Why doesn't it record?
I had a lot of problems with the blank CD's and tried a lot of blank CD's. After doing many hours research I finally found that the 'Memorex Brand Music Digital Audio" blank CD's were all I could find that would record from cassette to CD. You may find other brands that work but the key I found was the words 'Digital Audio' and many posts said the same thing. I bought mine from America from 'SimplyBestDealsOnline'. Really hope this helps. Susy.
Jul 18, 2014 | Teac AD-RW900 CD Recorder with Cassette...
CANT TRANSFER CASSETT TO CD
Hi Margaret,
You can download the manual for this device here. The downloaded file is called "ad-rw900.pdf" and should be found in your download directory.
Locate and open the file (Adobe Reader) and review page 31. Here you'll find the details to go about recording a CD from the source you've selected with the "Input Select" button. When recording to a CD-R or CD-RW with a cassette TAPE (or LINE IN or PHONO) as the source, you must manually set the recording level as directed in step 5 on page 32. Check the blank recording media. The device is ONLY capable of recording on "CD-R" and rewritable "CD-RW" blanks (these are very different from DVDs of any type). The CD-R type will likely enjoy wider compatibility (than CD-RW types) when played back on a different (car or other) CD player.
I hope this helps & good luck!
Dec 16, 2013 | Teac AD-RW900 CD Recorder and Auto Reverse...
Does it record live?
Sure, why not? If you run mic to mixer then to unit you can. You can't just plug a mic into it and record.
Jan 06, 2011 | Tascam CD-RW900 CD Recorder with MP3...
OPC Error
It implies a media Optical Power Calibration problem (google it). Did you recently start using a different type or brand of disc?
Jun 28, 2010 | Philips CDR775 2-Disc CD Recorder
What CD types does the PD887 play (CD-R, CD+R, MP3 format)?
You will have to experiment on this unit. I have looked at the owners manual and it does not refer to ANY type of recordable media. Your unit may not be able to play any recorded media. That is why I suggest that you try -R first, then you may want to try a Audio CD, specifically made for audio.
Here is a link to your owners manual if you need it.
http://www2.panasonic.com/consumer-electronics/support/Audio/Technics-Audio-DJ/Technics-CD-Players/model.SL-PD888
I hope that this helps you.
If you need any further assistance please respond to this post.
asnowman
Apr 12, 2010 | Technics SL-PD887 5-Disc CD Changer
Optical error
Your laser is failing. There is a test mode sequence you can try to re-calibrate it but to be honest it's the beginning of the end. I can supply replacement laser assemblies depending on where you are in the world or I can email you the service manual so you can try adjusting it yourself. Email me via ebay - fluffcat1
Audio cdrw's are still freely available in the UK.
Dec 28, 2007 | Philips CDR775 2-Disc CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Tascam Cd-rw900sl Cd Recorder/player Logo
76 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
