Question about Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer
Reset the NVRAM on a xerox phaser 3635 - Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer
4 Suggested Answers
SOURCE: xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Posted on Dec 15, 2009
SOURCE: How do I print to
This is a silly problem to have to fix but here is how you do it.
Go to Printers and Faxes, right click and select properties.
Then select Printing Preferences.
In the window that pops up, there is a paper option, click on the drop down arrow and select advanced paper selection.
In the next window where it says Output paper type, select 'AUTOMATICALLY SELECT' as opposed to Printer Default type.
This will solve your issue with this printer. It's kind of lame to have to do this but it works.
Posted on Apr 14, 2011
brett207
  • 231 Answers
SOURCE: Xerox Phaser 8860 error code 04, 025,.46:0?
This fault code indicates a problem with the process control system.
Cannot successfully move the transfix mechanism to home position.
Check for obstructions around the Printhead. Look for ink blobs in gears of the tilt drive.
Clean any ink or debris which may be restricting movement of the drive train or Printhead.
Posted on Jul 03, 2012
How set factory default xerox 7800
Solution : Reset the Printer to the Factory Defaults (Reset NVRAM) WARNING: Only use the tool when directed to by Xerox Service. All user and system settings will be lost.
  1. Select [Printer] on the Touch Screen.
  2. Select the [Tools] tab.
  3. Select [Setup].
  4. Select [Service Tools].
  5. Select [Reset NVRAM]. A confirmation screen will be displayed.
  6. Select [Reset NVRAM] again.
Related Knowledge Bases:
Mar 05, 2014 | Xerox Printer Division Xerox Phaser...
How to reset admin password on phaser 3635
xerox machines come with default passwords.
once that password is changed only the changer knows it.
should he forget or lose the password he flat has a problem.
the reset requires a xerox laptop/tech to reset and they "will bill" you for doing it.
Jul 01, 2011 | Xerox Phaser 3635MFP/X Multifunction...
Please help. The device prints once and then stops printing until restarted. This process continues between every print job. The message printed out from the printer is as follows: ERROR:...
This is a corrupted Postscript error.
Possible solutions are, reload up to date driver and/or firmware. Go to Xerox website address below for drivers and firmware.
http://www.support.xerox.com/support/phaser-4500/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB
This could also be a program specific problem, try printing from another software package.
Finally, you could try an NVRAM reset. Go to 'Troubleshooting', 'Service Tools', 'Reset NVRAM'. WARNING, before performing an NVRAM reset, print out a configuration page. 'Information', 'Information Pages', 'Configuration Page'. This print out will give you all the printers settings, including your network settings, which will be lost through the reset. You will need to re input them through 'Printer Setup', 'Connection Setup', 'TCPIP'.
Hope this helps.
Jan 21, 2011 | Xerox Phaser 4500 Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Reset xerox phaser to factory settings
Try performing an NVRAM reset, located in 'Troubleshooting', 'Service tools', 'NVRAM reset'. I would advise printing out a configuration page first 'Information', 'Information Pages', 'Configuration Page'.
Hope this helps.
Dec 15, 2010 | Xerox Phaser 6360 Laser Printer
How do I reset a Xerox Phaser 4500 Centreware password to factory default.. or what is the factory default password? I have on which has been changed and nobody seems to know the PW anylonger
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Mar 03, 2010 | Xerox Phaser 4500 Printer
Xerox phaser 8560 nvreset - how?
Jun 03, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 7300
You need to go to theExecute a NVRAM Reset in Diagnostic Mode sceren and find service diagnostics and Execute a NVRAM Reset. You most likely have some software corruption that needs to be cleared.
Dec 16, 2007 | Xerox Phaser 7300DN Laser Printer
Error code 11,009,46:1444 on Xerox Phaser 8500
A fault code search on Xerox's website says this is an electronics module interface fault--just doesn't say how to fix it!!
Oct 03, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer Logo
498 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
