Philips LFH9600 Digital Pocket Memo with Speech Exec Pro Dictation Software, LFH9600,LFH 9600/00B,LFH9600/00B,LFH-9600/00,DPM9600,DPM-9600, LFH-9610, LFH-9620, LFH 9600/00C,LFH-9600, LFH9600SR Logo
A
Anonymous Posted on Feb 12, 2014
Philips 585 dictaphone how to open
Does it need batteries
My dictaphone 1243 wont record sound
I'm sorry to hear that your Dictaphone 1243 is experiencing difficulties with recording sound. Here are a few troubleshooting steps you can try to resolve the issue:
1. Check the microphone: Ensure that the microphone is not obstructed or damaged. Clean any debris or dust that may be affecting its functionality.
2. Volume settings: Verify that the volume is not set too low or muted. Adjust the volume settings accordingly.
3. Batteries: If your Dictaphone 1243 operates on batteries, make sure they are charged or replace them with fresh batteries. Insufficient power can affect the device's performance.
4. Recording mode: Confirm that you have selected the correct recording mode. Some devices have different recording options, such as voice activation or manual recording. Ensure you have chosen the appropriate mode for your needs.
5. Storage space: Check if there is sufficient storage space available on your device. If the memory is full, it may prevent further recordings. Delete unnecessary files or transfer them to another storage device to free up space.
6. Reset or firmware update: If the above steps do not resolve the issue, you may consider performing a reset on your Dictaphone 1243. Consult the device's manual or contact the manufacturer's support for instructions on how to reset the device. Additionally, you could check if there are any firmware updates available for your device and apply them if necessary.
If none of these steps help to resolve the problem, it might be best to reach out to the manufacturer's support team or consider taking the device to a professional technician for further assistance.
1helpful
LFH9380/27 Philips memo dictaphone Won't turn on with new batteries
Please ensure that the product has no limit on the brand of batteries that can be used in it. If you can, please stick to the same brand that was initially used by your dictaphone. If these brand of batteries do not work, I would call philips to ask about the nearest repair vendor to you. That vendor should be able to troubelshoot and fix your Philips device.
Thank you.
1helpful
User manual for phillips dictaphone LFH 0862
http://download.p4c.philips.com/files/l/lfh0862_00/lfh0862_00_dfu_aen.pdf
My dictaphone is playing super fast. I do not know what is wrong with it. If anyone can help me that would be great. Thx!
Hello make sure the Speed control at front is on center if yes when is hapening make sure that you press the play button on the unit wile this is hapening just unplug the pedal if the problem get fix playing, your unit with out foot control you need a foot pedal replacement if not sounds like a bad motor I'm senting a link for a replacement pedal and a service place in case you need to send your unit to repair http://www.tvps.com/Products/ECS-IN-585-Heavy-Duty-Foot-Pedal---Pre-Owned-IN585__ECS-P-IN-585.aspx
Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
1helpful
2answers
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
2answers
Dictaphone foot pedal
It would be easier/cheaper to buy another foot pedal.
The older style had "leaf" switches in them and they are adjustable from below the foot control. There are 2 screws underneath each switch. Loosen up the one closer to the front of the pedal (just a little) and tighten the one in the back the same amount. This will raise the angle of the switch to make it more sensitive (lighter pressure to activate).
Dictaphone does not turn on
There is a small hole in the back of the unit. This activates the firmware update. My experiense is someone pushed this in with a pin and caused the switch to be stuck. You can disassemble the unit and use a pin to pry the bubble switch up or off. This switch is only needed to update the firmware which can also be done thre software so is not needed.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
