Question about Dell Vostro A860 Notebook
Vostro dont start
Even i have plugged into the wire or on battery, the notebook want start. When i press the power button the battery led left down just blink..nothing else happen.. What that means?
  • Dell Master
  • 9,742 Answers
There is a coin cell style battery inside that keeps the cmos values while the notebook is off. In time that battery will run down and needs to be replaced.
Posted on Jan 15, 2016
5 Suggested Answers
  • 3940 Answers
SOURCE: Dell M1530 wont turn on
A flashing ON ON Lock LED sequence is indicative of a failed Motherboard
Posted on Jul 10, 2009
Ricky8
  • 337 Answers
SOURCE: Hi, I have bought this dell vostro 1015 laptop
It sounds like your hard drive has gone bad. As this is a laptop you can try to reseat the hard drive, if that does not help then it might be a case of hard drive crash.
Posted on Oct 29, 2010
  • 6771 Answers
SOURCE: VOSTRO 1320 doesn't turn on
That would leave the processor ic, usually most motherboards do not include that.
Posted on May 05, 2012
krbshg
  • 430 Answers
SOURCE: vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Posted on Aug 06, 2012
Vostro 1400 wont turn on. When press POWER first and then 5th blue LED turns on after seconds 5th and then first blue LED turns off.
drain the power from the laptop by disconnecting all sources of power including disconnecting the battery. Then press and hold the power button for 10 to 20 seconds. Then plug your power adapter in and power up the laptop.
Mar 11, 2014 | Dell Vostro 1400 Notebook
Dell vostro 1000 power button press on..but lap is not working
unplug the power chord, take the battery out for 30 seconds. plug them both back in, restart.
Let me know.
tony
Feb 09, 2013 | Dell Vostro 1000 Notebook
Vostro 1400 won't turn on
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
May 05, 2012 | Dell VOSTRO 1320 13.3-Inch Laptop (2) PC...
I press the power button on my Dell Vostro 1500 and the HDD runs and the num lock light stays on and the scroll lock and caps lock flash and the DVD drive light stays on then the thing just shuts itself...
There are 9 states for LED error codes on this model. The error you're describing indicates that the laptop does not detect any RAM (memory sticks). Since you tried to isolate bad memory stick it looks like your motherboard has a problem and needs to be replaced.
Jul 28, 2011 | Dell Vostro 1500 Notebook
The a lcok is flashing and my vostro 1500 will not start, what can i do>
Hi ekazar,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Jan 12, 2011 | Dell Vostro 1500 Notebook
Power problem in monitor
This type of problem generally occurs when adoptor stops working and battery goes down. Show first of all check your power adoptor, its working or not, to check-out remove battery and use power adoptor then try to boot. If there is power led on means adoptor is ok otherwise try to reconnect and also check whether the power supply is ok for adoptor. For canfirmation use another adoptor.
If above not working then you can try to these steps:
1. Remove Power connection (Adoptor connection to Laptop).
2. Remove battery.
3. Re-Connect power to laptop.
4. Make switch on.
If above does not work then after step 2 try the followings
A. Press and hold power button for abt 20-30 secs. keep holding on and insert Power connection now if power led get on leave the button. After that it should on.
If all above didn't solve your problem, then its time to take tour of service centre.
Thanks and Good Luck
Iqbal
Aug 16, 2008 | Dell Vostro 1500 Notebook
Dell Vostro A860 Notebook Logo
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
