Question about InFocus IN34EP Projector
Infocus in 34ep all leds lit
Just stopped
No picture after power on
if there are no leds lit, replace the power supply. if the leds are on and fans are on, the colorwheel may be bad. if the colorwheel spins, the lamp is bad.
Mar 01, 2010 | InFocus X1A Multimedia Projector
Infocus x2 fan for lamp wont turn on
if there are no leds lit on the top when you turn the switch on, you have a bad power supply. if the leds are blinking, check your lamp door switch. if it's not closed, nothing will turn on.
Feb 10, 2010 | InFocus Office Equipment & Supplies
In72 does not power up. I think that it is a blown fuse. Where is this fuse located
if there are no leds lit on the top, then it's a power supply issue. open it up and check the fuse on the power supply (next to where the cord plugs in). if the fuse is ok, you'll have to replace the power supply. you can get parts from an infocus service center or send it to them to repair. either way, try www.avsolutionsny.com. they're really good.
Jan 20, 2010 | InFocus IN72 Multimedia Projector
Infocus lamp replaced - still does not work. LED lights on control panel not on either.
without knowing the model of projector, i would say that you need to replace the power supply. the leds are lit from the initial 5v when the power supply is on. no leds, bad ps.
Jan 02, 2010 | InFocus Office Equipment & Supplies
It was running & just shut down. wont even power up ! nothing.I checked the cord & it's fine????
if a red led is blinking, it may have overheated. if there are no leds lit, you'll need to replace the power supply. you can get the part from an infocus service center and replace it yourself or send it to one for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Jan 02, 2010 | InFocus LP640 Multimedia Projector
New lamp, no power!
if there are no leds lit, i'm surprised that it powers up. but if there is no light when the fans are running, it may be the ballast that needs replacing.
Oct 14, 2009 | InFocus ScreenPlay 5000 Multimedia...
Infocus sp 5000
if there are no leds lit on the top, check the lamp door switch. if the switch is bad or isn't activated by the door, it won't turn on. and there is a fuse on the power supply, but chances are, it's the power supply itself that is bad.
Aug 10, 2009 | InFocus SP5000 Home Theater Projector,...
InFocus LP120 Powercycles/Shuts Off/Does Not Stay On
what is the led doing? what coloris it? and if it is blinking, how many times? this will tell you the problem.
green (flashing and solid)- all is well
red flashing:
1 time- lamp won't strike after 5x
2 times- lamp has over 2000 hrs. replace lamp
3 times- lamp failure. replace lamp
4 times- fan not working.
5 times- projector running too hot. needs cooldown
red led lit solid- undiagnosed issue. send in for repair.
if your projector is under 2 years old, it's under warranty, but it seems unlikely.
Aug 10, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Intermittent Power up / dn
HI-
The projector is overheating, try cleaning the filters for the fan.
Hope this helps
Oct 29, 2008 | InFocus LP 600 Multimedia Projector
Projector will not come on
on the top panel. if you get no leds lit, the power supply is bad.
Sep 08, 2007 | InFocus Play Big IN74EX Multimedia...
InFocus IN34EP Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
