Question about KitchenAid REFRIGERATOR DRAWER
Kitchenaid 2 drawer refrigerator - KitchenAid REFRIGERATOR DRAWER
3 Suggested Answers
mrfixit3667
  • 262 Answers
SOURCE: KitchenAid KSBP25FJSS01 side-by-side refrigerator
Its not a major problem... It could be any of the following. The evaperator fan is not working in witch case the temps will rise soon and quickly you can check this by opening the freezer door and push the light switch if there is one and listen for the fan.
Next look at the back wall of the freezer and look fof FROST if you have frost then you have a defrost problem in withch case it could be a heater, limiter, timer, or control board.
or your thermostat is bad and is letting the compressor run longer than normal.
This should cover the most common problems.
Posted on Sep 05, 2010
gwhagemann
  • 114 Answers
SOURCE: Fruit is freezing in the bottom drawer of the KitchenAid KSCS25FKSS Side by Side Refrigerator
There is a chance that your refrigerator needs defrosting. Remove everything and unplug your refrigerator, open the doors and let stand for 12 hours. Sometimes the air vents restrict with ice causing this trouble.
http://www.on-timeapplianceplano.com/refrigeratorrepair.html
Posted on Jul 23, 2012
My Kitchenaid refrigerator deli drawer freezes everything, how can I fix this?
Check the air flow vents for ice buildup, this happened with my whirlpool fridge. Hope it helps.
Feb 03, 2015 | KitchenAid Refrigerators
Kitchenaid 25 cu. ft. side by side is freezing food in the refrigerator side(meat drawer and crisper)
Have you checked the temperature setting for the fridge? It may be set too low. There also may be an adjustment on the drawer for the crisper that can be adjusted (typically a slide adjustment.
Dec 05, 2014 | KitchenAid Refrigerators
How do i replace the small post that the crisper drawer rides on ?
you need a different site for this question this is a auto help site.
Sep 05, 2014 | KitchenAid Superba KSRG25FK Side by Side...
The middle support that holds up the crisper drawers has broken
Check with KitchenAid regarding replacement of the part. You also can try an appliance parts supplier as the tab may be a frequent failure item.
Nov 17, 2013 | KitchenAid Architect KBFA20ERSS Stainless...
Jul 23, 2012 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Aug 02, 2009 | Refrigerators
We have a KitchenAid KBRS19KTSS00 bottom freezer frige that keeps getting frost build-up and the food doesn't stay frozen....could it be frost behind the drawer that needs to be thawed out to make the...
If the door has a gap, certainly ice build up will occur on the evaporators and block the air flow which will just accumulate more and more if you don't defrost it first. make sure the doors always shut.
Dec 17, 2017 | KitchenAid 20.3 cu.ft. Counter-Depth...
KitchenAid REFRIGERATOR DRAWER Logo
80 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
