Question about Vizio L32 32 in. LCD HDTV
TV with a cable card slot - Vizio L32 32 in. LCD HDTV
Hello,everyone!! i have lenovo ideapad y560 with inbuild tv tuner & also a connector wire to connect dish cable to laptop... but my question is that how do i watch tv on my laptop OR in which...
Hi
TV tuner cards allow you to view programming on a computer system. Although desktop computers allow you to install internal TV tuner cards, laptop systems do not have the available space for internal cards. Because of this, laptop computers have PCI express card slots. This slot allows you to install and remove (at your will) additional hardware, such as TV tuner cards.
  • TV tuner card
  • Driver installation CD
  • Software installation
  1. Locate the PCI express card slot (located on the side of your computer opposite the disc drive). Push in on the protective cover on the slot to unlock it from the case. It pops out slightly, allowing you to remove the card.
  2. Slide in the TV tuner into the PCI express card slot. The card clicks into place and a light blinks on when the card has connected successfully to the laptop computer.
  3. Insert the driver installation CD into the disc drive of the computer. Momentarily a driver installation wizard appears on the screen. Click "Next" on the welcome page, then accept the given license agreement. Choose "Next" two more times, then select "Install" and the drivers from the driver installation CD install onto the computer.
  4. Eject the driver installation CD and insert the software installation CD. This is the program you use to view the connected receiver. As with the driver installation CD, wait for the installation wizard to load up onto the screen. Accept the license agreement, leave the installation name and location blank, then click "Install" to install the software.
  5. Restart the computer. Upon restart the laptop is ready to begin using the TV tuner card.
Jun 12, 2011 | Lenovo IdeaPad Y560 Laptop
I have a SAA7130 Analog TV Card. I split the signal from a cable TV line to a Tv, where it works, to the cable connector on the card, which is in a PCI slot on my new COMPAQ Presario Model AY030AA#ABA...
Hi you should make sure the TV card is fitted properly into the slot and then reinstall the drivers for the TV card.
Please let me know if you any questions Thanks for asking
Jul 23, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Intex tv tuner card SAA713x and computer sound on one point
this will make your life alot easier
http://www.radioshack.com/product/index.jsp?productId=2103863
best way to do it bud
Aug 20, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
What is a cabel card
A cablecard is the size of a credit card use to view or record digital cable channels on a digital recorder,personal computers and tv s without the use of outside equipment like (stb) set top box provided by your cable company, below is a picture of one hope this helps.
Aug 12, 2009 | Zenith Z37LZ5D 37 in. LCD TV
What do TV cards do when installed in computers
TV cards fit into PCI or PCIe slots depending on the bus speed of the card and the motherboard. TV cards provides a port for CAT-V cables. With TV cards, you can watch local TV stations and or cable TVs in your PC. Connection is through a CAT-V cable.
Jul 26, 2009 | Computers & Internet
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS 1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot) 2)plug ur spker to line out jack(green slot in computer) 3) double click on small spker icon (left side to ur screen near clock) 4) click options menu>Properties>chose audio out option 4m drop box(see image)
11_2_2011_5_27_42_am.jpg5)click rear pink in >ok And all done have fun
Jun 18, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Got a new Dell Studio 17 laptop with TV Tuner, but TV wont go
if it is not finding channels, it could be a physical connection problem from the antenna or the antenna lead on the device.
Mar 10, 2009 | Dell Studio 17 Laptop
Cannot watch tv or listen to radio
you must first check if the TV card is attach firmly at the motherboard and that the slot is clean (PCI slot etc.) and attach an antena or cable to your TV card.
i hope this video may help you even though its not the same tv card as yours but the installatio process is the same.
i hope i was able to help you with your problem. TC!
Oct 15, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 TV Tuner/FM... Problem
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot)2)plug ur spker to line out jack(green slot in computer)3) double click on small spker icon (left side to ur screen near clock)4) click options menu>Properties>chose audio out option 4m drop box(see image)
11_2_2011_5_27_42_am.jpg5)click rear pink in >okAnd all done have fun
Jun 26, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
