Question about Cerwin Vega Audio Players & Recorders
No sound coming from my Cerwin-Vega P-Series P1800SX 18 Inch Active Subwoofer
  • 71 Answers
SOURCE: Cerwin Vega V-10S Subwoofer doesn´t sounds good
dear "rai17"
This, to me, is most likely the voice coil inside the driver rubbung against the yolk plate, or possibly the spyder slapping the metal plate underneath it, or the amp-(if it has one?) getting tired. this can occur from poor build quality, or playing the subwoofer too loud. depending on how much it cost you, you may want to get it repaired(voice coil re-alignment or something or new amp). But the way it seems, it is probably the driver itself. subwoofers get looser as they break in. This one may have been over-broken....sorry
I hope this helped clarify what is happening!
Posted on Jun 09, 2009
SOURCE: Cerwin-Vega 12'', no power
It should have a small fuse on the board between the transformer and the board. Check that first. If it is good see if the transformer is putting out any voltage. Two easy fixes that can be done in house...
Posted on Jan 31, 2010
  • 308 Answers
SOURCE: cerwin vega passive subwoofer model sw-12b
Passive woofers are hooked up to the output of a sub amp.
Active woofers are hooked up to the sub out of a receiver. They have the amp built in.
Posted on Mar 09, 2010
technical114
  • 1851 Answers
SOURCE: I have a cerwin vega subwoofer that keeps blowing the fuse
Take a look at the Voltage selector switch (if one is existing). It may be switched at the wrong position. In that case, I hope that the power supply is not burned out (if it is set at the wrong position).
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jun 13, 2010
chrisreitano
  • 85 Answers
SOURCE: Cerwin Vega SUB8...how do I connect
grady66,
We will start with the easy one, Phase. The phase selector is a setting that can be adjusted by sound; which one sounds better? Either one will work fine. It's mainly for situations where the sub enclosure is located at a distance or behind the listening area. The 'in and out' crossover selector and the input from the receiver goes together. The 'in and out' crossover selector is asking if you want to use the internal crossover to block the bass from getting to the satellite speakers. Most home surround sound receivers only have the one sub out and most subs have both left and right inputs. When there is a single signal being fed to the sub you use the subs left input or buy a splitter and send the signal into both left and right, but either way will work equally the same.
There is two ways to connect the speakers to the receiver.
1) Cross-over 'In': you connect the output speaker wires from the receiver to the speaker inputs on the sub and the speaker outputs on the sub to the satellite speakers; the sub will get its sound from the input speaker wires.
2) Cross-over 'Out': you connect the sub to the receiver using the receiver's single sub out, then connect the satellite speakers directly to the receiver's speakers outputs; in this configuration the satellite speakers are given a full range of signal including the bass.
I have used #2 with the same system and had great results.
-Chris
Posted on Aug 13, 2010
Where can i find an amplifier for a cerwin vega hts 12a
Subwoofer Plate Amplifiers
What you need is a plate amplifier. You'll get more bang for the buck by using an after market one. They are simple to replace. Dayton is a popular brand. They use an active variable crossover .
May 22, 2014 | Cerwin Vega HTS12A Subwoofer
When turning on the power on my cerwin vega 15" sub the protect light which is a built in protection on the amplifier keeps coming on the power on light does not come on at all just the protect light
The sub could be shorted or the wire connections of the sub could be shorted, or there could be an internal problem with the amplifier such as a shorted output stage or failure of some other component(s)
Feb 21, 2013 | Cerwin Vega Audio Players & Recorders
I own a CERWIN-VEGA V-12S 12" Front Firing V
You may have only messed up the crossover circuit. Try changing the crossover frequency and see if hte behavior changes. If so, then the parts cost should be minimal. If the behaviorr remains the same, there will need to be more investigation done internally. This is not a problem that is likely to be easily resolved remotely. Can you update this with your location? I may be able to provide a recommendation for a service shop.
Dan
Jan 05, 2011 | Cerwin Vega V-10S Subwoofer
Cerwin vega passive subwoofer model sw-12b
Mar 09, 2010 | Cerwin Vega Audio Players & Recorders
Jan 01, 2010 | Cerwin Vega LW12 Subwoofer
I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Mar 24, 2008 | Audio Players & Recorders
dear "rai17"
Oct 09, 2007 | Cerwin Vega V-10S Subwoofer
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Steve
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
