Question about Simmons Outdoor Yardage Master 801446 Rangefinder
My Simmons Tilt Rangefinder is showing me Meters instead of yards how do i get it back to showing me yards?
Need to go back to yards from meters
To select between yards and meters, press and hold the POWER/FIRE button
Oct 27, 2014 | Bushnell Golf Tour v3 Slope Patriot Pack...
Change from meters to yards on bushnell chuck adams rangefinder
First, remove the battery then replace it to reset the unit, then ...
Taken word for word from the manual: While looking through the eyepiece, press and hold the POWER button down for approx. 5 seconds. During this time all liquid crystal segments and icons will be displayed. As you continue to depress(hold down) the power button, the display will toggle back and forth between Yards and Meters. Once the unit of measure desired is displayed, simply release the power button. The device will return to the last unit of measure setting used each time the unit is turned on.
Sep 12, 2012 | Bushnell Optics
How can i change yards into meters
1 yard = .9144 meters yards * .9144 = meters
Jul 08, 2012 | Cabela's CLR 1200 Laser Rangefinder
How do you make it go back to yards? somehow it got on meters
Step 1: Determine the model of your Bushness rangefinder.
Step 2: Repost your query, being sure to include the information from Step 1.
Feb 21, 2012 | Bushnell Optics
I have the Leica CFR 1200 Rangefinder. Does this readout in Yards or Meters and can it be changed?
There are two different sub-models of the CRF 1200. The 527 reads in meters while the 523 reads in yards. This is not something that can be changed by the user.
Oct 30, 2010 | Leica Rangemaster 1200 40527 Rangefinder
Can my bushnell yardage pro rangefinder be calibrated. It is 4 yards off at 30 yards and 7 yards off at 40 yards. So on and so forth
I would send this unit in for repair to have it inspected you can reach their customer service at 800-423-3537 option 1.
Oct 04, 2009 | Bushnell Yardage Pro Tour Rangefinder
Recently purchased ypc 600, no manual, on screen read-out is in meters. can I switch this to yards?
Two buttons on the top. The big one is the power/fire button, the smaller one is the mode button. Hold down the mode button for at least 5-6 seconds and it should switch to yards instead of meters. (Y to M)
Good Luck!!!
MTG
Jun 20, 2009 | Bushnell Yardage Pro 600 Rangefinder
Wrong type of measurement showing
On most of the bushnell units you just hold down the MODE button for about 5 seconds and the unit should switch from yards to meters....or vice versa
Mar 13, 2009 | Bushnell X-500 Rangefinder
Incorrect distance or Calabrated wrong
Sounds like the unit is reading in meters instead of yards....Hold down the mode button on the side for about 5 seconds. It should switch modes.
Jan 12, 2009 | Bushnell Tour V2 Pinseeker Laser...
Changing Modes
press the power button to turn the unit on then, while looking through the monocular, press and hold the mode button for 5 seconds. You will see the unit of measure indicator switch from meters to yards. Good Luck!
Apr 14, 2007 | Bushnell Yardage Pro 800 Compact...
Optics Logo
197 people viewed this question
Top Simmons Outdoor Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Jerry Kramer
Jerry Kramer
andrewcahoon
Are you a Simmons Outdoor Optic Expert? Answer questions, earn points and help others
