Question about Electrolux Dryers
E63 error code
Electrolux dryer showing error code E63 what does that mean
  • 744 Answers
SOURCE: dryer shows E63 error code?
The error code E63 is a high temperature warning
If you dryer is under warranty, take advantage of it. If not it may be a failing sensor or possibly a control board.
Posted on Apr 11, 2009
protek480
  • 1714 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
SOURCE: electrolux dryer error code e63
I have ann E63 code on my Electrolux dryer. THe vent pipe was somewhat clogged but now is cleaned.What do I do?
Posted on May 08, 2010
rylee_smith
  • 8619 Answers
SOURCE: Electrolux dryer has code of
Hi
Thanks for using FixYa. Error E63 in your Electrolux Dryer indicates that the temperature inside is too hot/overheating, to start with check the vent and try to clean it. If still it's not resolved then the issue is with the thermal fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 09, 2010
richroth
  • 9472 Answers
SOURCE: What is Electrolux Dryer Code
Error E63 in your Electrolux Dryer indicates that the temperature inside is too hot/overheating, to start with, check the vent and try to clean it. If still it's not resolved then the issue is with the thermal fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel.
Posted on Jan 15, 2011
Wire testing on Electrolux E63 error.
I appreciate your post, Tim Davis!
From what you have described your Electrolux dryer is displaying an error code "E63". I understand that you have performed several tests on different electrical components within your dryer. I see you wanted to further test the wiring and I would recommend having a professional technician come out to perform a diagnosis. Since you have completed many tasks there are no instructions I was able to locate that provide further wire testing on your dryer. Best of luck! -Matt
Jan 07, 2015 | Electrolux Dryers
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
Electrolux dryer will not start code E-63 appears on the screen
Hi boltonjamese...
E63 error code means that your dryer thinks the temperature is too hot.
If your unit is still under warranty they should fix it under warranty so I would highly recommend calling warranty to correct this issue as any problem to fix this will involve replacing a sensor or a control board.
Please take time to rate me
Sep 24, 2011 | Electrolux Dryers
What is Electrolux Dryer Code E63
Jan 15, 2011 | Electrolux EIED55H Dryer
Im getting the E63 error code,what does this mean and can I fix it myself ??? Any advice is greatly appreciated. Thanks, ...
The error code E63 is a high temperature warning:
Oct 21, 2010 | Electrolux EIED55H Dryer
Electrolux dryer has code of E63
Hi
Thanks
Rylee
Oct 09, 2010 | Electrolux Dryers
What doe error code E63 refer to? thanks
"E63" error code means that your dryer thinks the temperature is too hot. Most of these units should still be under warranty so I would highly recommend calling warranty to correct this issue as any problem to fix this will involve replacing a sensor or a control board which involves high risky things to be done. So its safe to reach the company service technician to fix this issue.
Thank you!!
Jun 01, 2010 | Electrolux EIED55I Dryer
Electrolux dryer error code e63
Jan 02, 2010 | Electrolux Dryers
Dryer shows E63 error code? What is it? Should I call service?
Apr 11, 2009 | Electrolux EIED55H Dryer
Dryers Logo
15 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
