Question about HP Office Equipment & Supplies
Reset waste ink counter on hp 5515
Black ink stop printing and puddling of ink under ink carriage
SOURCE: waste ink tank full
please help me for repair waste in tank full canon ip3300.
Posted on Jan 24, 2008
Mrvica
  • 167 Answers
SOURCE: Reset Waste Ink Canon MX318
Because It is full. And replace or you can clean it. Either way you must any of this two things.
Good luck.
Posted on Sep 16, 2008
pineworks
  • 4041 Answers
SOURCE: Current Problem on Printer """E5"""
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Posted on Jan 25, 2010
  • 352 Answers
SOURCE: Canon pixma mp240 ink reset
Thats funny, cause I took the cartridges out and left the lid up, unplugged it, plugged it back in with my finger on the power button and tapped the stop/reset button twice. Put the cartridges in, pressed the color start, after some moaning a test page printed. I unplugged it again, plugged it back in and I had full ink Levels!!!
Posted on Jan 27, 2010
CW Oly
  • 240 Answers
SOURCE: How to reset epson stylus d120 waste ink counter?
You don't want to reset the waste ink counter unless you have removed all of the waste ink. Unless you feel like totally dismantling your printer and hand washing the felt pads that are currently soaked in ink you'll probably want to have it serviced professionally or just replace it. Most times replacement is less expensive. Resetting the waste ink counter without cleaning out the waste ink can, and likely will, result in waste ink eventually overflowing out of the the bottom of your machine. Be cautious.
Posted on Jun 09, 2010
What mean error code pixma printer mp 145 ( E 8) ?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code Message for Printer Canon MP145 and Canon MP160:
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Jan 02, 2011 | Office Equipment & Supplies
Epson R2400 paper and ink lights blinking red. Ink waste pad replaced and counter reset to 0. Lights still blinking red. Close inspection for any loose objects in printer but none found. Please advise....
Try to turn on your printer without the ink cartridges. When the printer starts and ask for the cartridges, put them back in.
(To remove the cartridges turn on the printer, watch the print head carriage move, when it is at the center quickly unplug the power cable, move the carriage by hand to a position where you can remove the cartridges, after removing the cartridges push the carriage to the right where it should be parked.)
Sep 02, 2010 | Epson Stylus Photo R2400 InkJet Printer
.error 1700 says waste ink absorber nearly
(In waste ink absorber replacement, perform
the EEPROM information print to identify if the main and/or platen
waste ink absorber should be replaced. After replacement, reset
the applicable waste ink counter(s).)
Waste ink counter reset See “Service mode operation
procedures” below.
The following 3 methods are available:
- Resetting the main waste ink counter (0%)
- Re-setting the main waste ink counter
value to 50%
- Resetting the platen waste ink counter
(0%)
<Service mode operation procedures>
1) With the front cover closed, and the printer power turned off, while pressing the Resume/Cancel
button, press and hold the Power button. (DO NOT release the buttons. The LED lights in green
to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.) During initial operations,
the LED blinks in green.
4) When the LED light sin green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
Time(s) LED Function Remarks
0 times Green Power off When the print head is not installed, the
carriage returns and locks in the home
position.
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter resetting Proceed to the step 5), and follow the
Waste ink counter reset procedures.
5 times Orange Destination settings Proceed to the step 5), and following the
Destination settings procedures.
6 times Green Print head deep cleaning
7 to 9 times Orange Not used in servicing
10 times Green Return to the menu selection
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu
selection mode automatically.)
<Waste ink counter reset procedures>
In the waste ink counter resetting mode, press the Resume/Cancel button the specified number of
time(s) according to the ink counter reset value listed in the table below, and press the Power button.
Time(s) LED Waste ink counter value
0 times Green Reset the main waste ink counter (0%).
1 time Orang
e
Reset the platen waste ink counter (0%)
2 times Green Re-set the main waste ink counter value to 50%.
<Destination settings procedures>
In the destination settings mode, press the Resume/Cancel button the specified number of time(s)
according to the destination listed in the table below, and press the Power button.
Time(s) LED Destination
0 times Green No change
1 time Orang
e
Japan
2 times Green Other than Japan (A4)
3 times Orang
e
Other than Japan ltr
Jun 24, 2010 | Canon Office Equipment & Supplies
Error 2
HI,
THe error E2-indicates no paper error
othe error codes:
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
Try resetting the printer,think this should solve your problem
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
RNJ VINODKUMAR
Oct 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
button pressing
Error Code :
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
E5 light
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
button pressing
procedures below.
procedures below.
Thanks, Joe
Mar 25, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber is full, waste ink full, waste ink absorber, a
may the error code or how many blinking can solve your problem
this is the list of error code
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
try this methode
Methode 1
service mode. (Waiting formenu selection)
button pressing
procedures below.
procedures below.
that's all
maybe it can fix your problem
thanks
Jan 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error Message 22, but can't reset it.
First make sure there isn't any thing keeping the carriage from moving freely, the reset as follows:
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
button pressing
procedures below.
procedures below.
Thanks, Joe
Dec 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Error code E5
hi dear
hi dear
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
try this methode
Methode 1
button pressing
procedures below.
procedures below.
that's all
thanks
cropp
Mar 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
21 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
