Question about Samsung RSH7UNMH 352 L Fridge Freezer Side-by-Side Freezer, A Energy Rating
Refrigerator not freezing - Samsung RSH7UNMH 352 L Fridge Freezer Side-by-Side Freezer, A Energy Rating
Roper refrigerator warms and freezes
More than likely, you have a failed component in the defrost system. Call a good, reputable, service company. You do not need to replace this refrigerator.
Oct 01, 2014 | Whirlpool Refrigerators
Items freeze on top shelf of refrigerator. All temps are per factory specs.
If it is only freezing on the upper shelf then you will need to replace the "air diffuser". It is not closing when the refrigerator temp is reached. Here is the part to order.
Nov 05, 2012 | Whirlpool GSC25C4Ey Side by Side...
Freezer freezing and refrigerator freezing
Search round the top/bottom/sides of fridge and freezer for a regulator switch. Usually a small serrated wheel numbered 1-5. It should be set at 2 or 3. Any more and you will freeze up.
Jul 12, 2012 | GALAXY Microsystems 25.4 cu. ft....
Suddenly the refrigerator is freezing everything we have not changed the settings we tried to even turn down and is still freezing the food.Help!
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 04, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My refrigerator is freezing everything! We have turned it up as far as we can and still freezes.
I think you have to choose +7 value of your freezing value as per your refrigerator. after that you will be able to still freezes your things.
Sep 25, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Fresh food side too warm
Refrigerator nguyen@ite.net 40 F or lower is the recommended refrigerator temperature to slow bacterial growth and maintain quality. Freezing occurs at 32 F; adjust refrigerator accordingly between 32 F and 40 F to prevent unwanted freezing, such as freezing milk.
http://lancaster.unl.edu/food/ciq-fridge-freezer-thermometer.shtml
Jun 09, 2009 | GE GSS25JFM Side by Side Refrigerator
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Food freezing in refrigerator.
I have a side by side GE Refrigerator only about 4 years old, the setting on the Refrigerator is set at 37 degrees but it continues to go to 20 degrees and freezing my vegtables. Help.
PS - i did vacumn the back filter a week ago with no help.
Jan 27, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Samsung RSH7UNMH 352 L Fridge Freezer Side-by-Side Freezer, A Energy Rating Logo
13 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
