Question about HP Laserjet P3015X Printer
Blank pages and error 13.05.00 - Laserjet P3015 & P4015
I've got two different model printers with the exact same issue. These are the Laserjet P3015 and P4015. The problem is as follows... If I print a single page (like a supplies status page) it will print a blank page. From Tray 1, if I try to print 2+ pages (like a configuration page) all of the pages will be blank. From Tray 2, if I try to print 2+ pages (like a configuration page) it will jam with error 13.05.00 and all of the pages will be blank. Swapping the toner cartridges does not change the problem. An Engine Test will print a blank page. A Half Self Test shows no image on the drum. On the P4015 I swapped the DC Controller, it did not change the problem. I'm extremely puzzled as to what is causing this issue. Blank pages and a jamming issue? I'm beginning to wonder if I'm missing a problem in the gear train or with one of the motors. Has anyone else seen this problem before and can offer some insight in how to fix it?
  • 27 Answers
SOURCE: Blank print out
This is laser scanner error message. The document is not being read from the data being sent. This could be a loose or damaged cable or bad scanner assembly. You can open it up and look for loose cables or connections to the board but otherwise if the scanner assembly is bad, it may require replacement. This should only be accomplished by a service professional as it is not a user serviceable problem.
Posted on Jan 29, 2007
Printerguy
  • 31 Answers
SOURCE: printing problems
Hi, There are 3 things that can cause blank pages. The most common is the laser shutter pops off on the spring side and blocks the laser from hitting the cartridge. The shutter opens when the cartridge is inserted. The cartridge guide that sits above and behind the cartridge misteriously gets eaten by the printer. Without it, the cartridge rides too high for the toner to transfer. The high voltage power supply goes totally dead. If the first 2 are ok, then replace the high voltage power supply. (There are 2 power supplies in the printer. One the low voltage power supply supplies voltage to all the boards, fans, etc. The high voltage ps only supplies voltage to the toner cartridge.)PS-The laser/scanner shutter is found under the top cover and below and by the front of the laser/scanner assembly (black box). Control of the shutter is on the left side of the laser/scanner. Good luck
Posted on Sep 04, 2007
  • 186 Answers
SOURCE: Page count unreasonable
Re you using genuine HP NEW cartridges? If not, you must make sure that whoever has re manufactured the ones you are using has replaced the chip on the cartridge. This tells the machine how many copies are on the cartridge.
Posted on Nov 15, 2007
Muggs01
  • 72 Answers
SOURCE: HP Laserjet 2200 Keeps Spewing Out Blank Paper
sounds like it has a solinoid that is stuck open.
Posted on Jan 16, 2009
leroyal
  • 2120 Answers
SOURCE: HP 2430 jams from optional tray 3 only.
Hi Rich,
I've had this problem too. I believe it's the post that holds the drive gears wears or becomes loose causing timing problems.. Unfortunately there's no spare parts available for the optional tray. You would have to purchase a whole optional tray.
Posted on Mar 12, 2009
How do I Fix HP Printer 50.9 Fuser Error online ?
50.9 Fuser error message HP LaserJet P4014 P4015 P4515 If you are seeing the message 50.9 Fuser Error on your HP LaserJet P4014, P4015, P4015 series printer, you have either a failing fuser or the wrong model fuser installed in your printer. (The fuser is the consumable part in your printer which heats up and bonds toner to the paper. Usually the fuser gets replaced several times over the life of these printers.)
HP makes 2 different model fusers that look very similar -- the P4014/P4015/P4515 series fuser, and the M600 series fuser. Because of the similarities in appearance, sometimes the wrong fuser gets installed in the wrong model printer and triggers a 50.9 error.
The easiest way to check which model fuser you have installed is to pull the fuser out of the printer and look at the fuser's barcode. It is easy to remove the fuser on these models; if you don't know how to remove your fuser see the removal instructions farther down this page.
Once you have the fuser removed from the printer, look at the barcode as shown below to determine which model fuser you have installed. For the P4014, P4015, P4515 series printers the fuser part# should read RM1-4554 as shown in the picture below.
Either way, whether you have a failing fuser or an incorrect fuser on your LaserJet P4014, P4015, or P4515, you can purchase a quality replacement fuser in the maintenance kit for the P4014, P4015, P4515 series. Click here to view our selection of fusers/maintenance kits. Call us with any questions toll-free 866-352-7108 or local 608-831-2396.
Removal instructions: How to remove the fuser from the printer
Turn the printer off and unplug the power cord. The fuser might be hot if you have been using the printer. As a safety precaution wait 30 minutes for the fuser to cool before proceeding.
If a duplexer is installed, remove it from the back of the printer.
Next fold down the rear door.
Flex the plastic arm-hinge (circled in red below) on the left bottom of the door . This will release the tab which holds the plastic arm in place, and will free the door.
While grasping onto both sides of the fuser, push the blue levers upward and pull the fuser straight out.
After you order a replacement fuser and it arrives, you can install the fuser by inserting the fuser and aligning the left side first. Push the fuser firmly on the left side, then the right--listen for the sound of both blue levers clicking into place. If the fuser does not click into place you run the risk of wearing out both the fuser and the gears that drive the fuser prematurely. Re-install the plastic rear output bin and you are ready to print.
Dec 28, 2017 | HP Office Equipment & Supplies
Laserjet P3015 displaying error code 59.30 how to resolve
this issue is comes from data transfer error,please delete all print command
Jul 28, 2016 | HP LaserJet Enterprise P3015d BW laser...
LaserJet P3015. Why is it printing dark background?
Hi Boateng Samuel,
I would be happy to help you with your P3015. Although the enterprise printer models are out of my support scope, I was able to find you the appropriate document specific to print quality. Please use the following document to troubleshoot the issue:
HP LaserJet P3015 Printer Series Solving Print Quality Problems
Best of luck, I hope this helps.
I work on behalf of HP.
Jul 17, 2015 | HP Office Equipment & Supplies
HP P3015 reset maintenance kit count
  1. Power off the printer.
  2. Power on the printer while depressing both the Go and Cancelbuttons. Keep the buttons depressed. The lights will begin to flash in sequence.
  3. Release the buttons when all three lights begin to flash in unison
May 29, 2013 | HP Laserjet P3015X Printer
Hp laserjet p4015 error 60.02
This is a motor lifter error for tray 2. Most times the issue is caused by a small spring which comes off the motor or the chasis where it attaches. See the attached page and look at item 3 as that is the spring. If it is ok, then you could try loosening the screw which secures the motor and then tighening it again. Do so with the tray removed. Attachments: icon_attachment.png 304522.pdf ‏119 KB
Feb 12, 2013 | HP Laserjet P4015x Printer
Stop printing ...Repace toner very soon...If you remove and restore toner it works for a few more pages
You haven't given much information on this, so please answer these questions to get a better feel of what is going on
1) Is this a new toner cartridge that you've installed? 2) Is it a refurbished cartridge? If so, manufacturer or clone? 3) How long has it been in the printer and when did this problem start? 4) Have you tried a different toner cartridge?
It could very well be the cartridge, especially if it is a refurbished/clone (not from the manufacturer)
May 11, 2011 | HP LaserJet P4015 Printer
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
Jan 19, 2011 | HP LaserJet 4350 Printer
51.10 ERROR
i cant print my document my hp laserjet p3015 print display error message 51.10. please slove this imdy.
Dec 13, 2010 | HP P3015 Laser Printer
3150 fax machine outputs a blank page when my fax sends to it
(05) Would you, please, SEND a fax from the machine that blank faxes are being received from to a different recipient on a different fax machine all together, please?
This will enable us to pin down which machine is really experiencing the issue.
Thank you
BJ @:)
Apr 17, 2008 | HP LaserJet 3150 All-In-One Printer
HP Laserjet P3015X Printer Logo
160 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
