Question about Pioneer VSX-818V-K Receiver
Pioneer vsx919ahk no audio output to speakers. Internal main power fuse is ok. Any additional fuses to check?
4 Suggested Answers
SOURCE: Pioneer VSX-D308 Receiver Problem
go through your mode channels to put it on surround sound
Posted on Oct 14, 2008
SOURCE: no power
I had the same problem. I picked up 3 fuses to replace inside the Amp. and it has worked ever since.
Do you havea manual for this that you could send my way via email?
Posted on Mar 15, 2009
SOURCE: Pioneer SX-203
Check the 2nd Tape monitor switch. If on it kills signal path.
Posted on Jul 19, 2012
B n O 8000 speaker dead, is there an internal fuse, output from tv ok mains fuse ok, no mains indicator light hence question
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 05, 2014 | Televison & Video
Tip
My Pioneer displays Overload
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
on Jun 22, 2009 | Pioneer VSX-D608 Receiver
No sound from Pioneer VSX-37TX
check the caps and output transistor the power ones and resistors
May 31, 2012 | Pioneer VSX-37TX
I hooked up a Niles speaker switcher to my pioneer vsx 521 k receiver.I tested it and immediately there was a smell and the receiver powered off . It won't come back on, is it a fuse or have I rui
The audio outputs have been fried, plus the main fuse blown. The power transformer will need to be checked for a open primary, I suggest you get a estimate first. My feeling is that it will be expensive.
Apr 07, 2012 | Pioneer Audio Players & Recorders
I have a Nuvo Grand Concerto System (NV-18GM) that I am setting up. I initially plugged it in to 240V mains power before realising I had to reconfigure a couple of internal wires (switching from the...
If the main amp section does not have it's own fuses, then the fuse might have blown, because the amp has gone. However I think it is highly likely that you have taken out the main amp, especially if it is a single IC that does all the work. You should try and determine if the amp section is getting power before replacing it.
Mar 19, 2017 | Audio Players & Recorders
Pioneer SX-2300 powers up, but no sound.
Does the output relay click about 5 sec. after powering on? If it does check if the tape2/tape monitor is on. Check speakers and wiring. Try headphones.
There aren't any fuses for the output.
If no relay then it probably needs output transistors and a few resistors.
Dec 17, 2009 | Audio Players & Recorders
I just bought a 98 concorde lxi and no sound coming out of the speakers, radio comes on and shows channels just no sounds
Hello georgouseyes,
The problem could be in the output from your receiver to the amp or in the amp itself.
First check to see if the amp powers up. If it doesn't, check the main power fuse (usually located under the hood near the battery). Also check the power and ground connections on both ends.
If the main fuse checks OK, check both onboard fuses. There's 2 35A fuses on the far right.
If the amp powers up OK and the onboard fuses are not defective, it's possibly the output from your receiver or line output converter. Replace the RCA cables with a known good pair. If there's still no sound, I'd suspect that the amp itself is defective.
Hope this helps.
Oct 17, 2009 | Infinity 475A Car Audio Amplifier
I have a pioneer Rx-570 stereo the fuse blowout i replaced the same fuse but blowout again I wounder what is the cause for it
hello my friend you have a short in the output ckt,also check the power supply for any damage(shorted) components. like diodes,caps,transistor.
but your main concern should be the audio output circuit.
caypianan@yahoo.com
Nov 07, 2008 | Pioneer Audio Players & Recorders
Pioneer Audio/video Multi-channel receiver Mod#VSX-D710S
Have you tried a 2nd source like the CD input or AUX input?
Have you tried the headphones..same static?
If nothing works then the output amp is broken. There could be internal fuses but only open a stereo when the power is DISCONNECTED. Then check for fuses
Feb 01, 2008 | Audio Players & Recorders
Amp blowing fuses
The amplifier probably has shorted output transistors.
Disconnect the speakers and RCA cables. Replace the fuses with two 10 amp fuses or a single 20 amp fuse. If the amp blows the fuse when it powers up, the outputs are almost certainly the problem. Don't try it with the two 30 amp fuses. The smaller fuses will provide more protection for the power supply. If the amp powers up with the smaller fuses and they don't blow, check the speakers and the wiring (for shorts to ground or shorts between wires).
Nov 22, 2007 | Rockford Fosgate p-450.4 Car Audio...
Pioneer VSX-818V-K Receiver Logo
42 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
