Question about Kitchen Appliances - Others
Melcom st6100 how to disable during high winds
2 Suggested Answers
  • 5 Answers
SOURCE: how do i turn off the chime when the door opens on
intruction manual?
Posted on Feb 23, 2010
Directions for filling bobbin in Singer Model 9217. Am I supposed to load the bobbin with the presser foot up or down?
The needle and feed dogs should not move while winding the bobbin (this is a safety function). If they do on your machine, then the mechanism that disables them during bobbin winding is malfunctioning.
Generally, is it not good to run the sewing machine without fabric between the presser foot and feed dogs. The feed dogs will eventually damage the underside of the presser foot and the presser foot will wear down the points on the feed dogs.
Dec 12, 2017 | Singer Sewing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
What does 3 flashes pause than 3 flashes over and over on a Viper 3105V one way alarm system mean?
The three-flash, wait, three-flash sequence indicates that either the nuisance prevention circuitry or another fault has been registered by Zone 3 or the door sensor. Nuisance prevention circuity is automatically activated when there are several faulty activation codes sent to a sensor. In turn, the door sensor is bypassed by the alarm which keeps the system quiet. This only happens when a specific threshold is reached in specific activation codes that are sent from the door sensor to the alarm cpu.
It would seem inadvisable to disable the door sensor when it is receiving faults. It might indicate someone is trying to boost your car. However, it is not as inadvisable as you might think.
The faults that activate the nuisance circuity tend to be lower-level faults and not the major ones that might trip the door sensor such as someone trying to slip the door lock or someone who might smash a window. In those instances, even though the nuisance circuity was tripped, the alarm will still work and sound, if it receives major faults such as the attempted to slip the door lock or the windows is broken.
The nuisance circuitry is meant to prevent the alarm from activating for multiple impacts to the door such as those that might be called during a high wind or if pieces of wood were blown against the car during a high wind.
Oct 30, 2014 | Vehicle Parts & Accessories
I have a 450 farm boss 50.2 cc how do i adjust the carb.so it will wind out to high speed
sounds like you should check the spark advance before adjusting the carb. As an engine accelerates, the timing of the spark must also adjust to occur sooner during the cycle.
Oct 19, 2014 | 2005 Honda CRF 450 X
MY MACHINE WONT SPIN
Check the voltage to the motor when the program goes to the spin cycle. If there is voltage then check for free movement and also check on the capacitor to the motor. In some cases the high speed coil winding to the motor for the high RPM spin cycle can be faulty.
Mar 13, 2012 | Washing Machines
I have a Hoover 750LA Top Load Washing Machine. It washes very well, but it doesn't seem to be spinning out. Clothes are still wet and a little soapy. How many belts does it have. Where is the pump on...
Try and choose a manual mode if there is one on the program controller. If this wont spins the motor it can be fault in the program controller unit.
You will need to check the voltage output from the controller during the spin cycle to confirm if there is a winding issue on the motor - if this is a high speed mode.
If so it is possible that the high speed winding is defective.
Jan 10, 2011 | Washing Machines
Which cable line to disable the wind sheld wipers
First, probably easiest to just go to a junkyard and get a new switch for like 5 bucks. Second, if you still want to disable it then just locate and pull the fuse.
Mar 22, 2010 | 1994 Toyota Camry
"High wind" sound following defrost.
Freon running through the feon lines can make some odd noises, usually a gurgling or higher pitched noise. If your freezer works fine with no more strange noises, then don't worry about it. If you have temperature problems or continue to have abnormal noises, then see if your freezer has the 5 year sealed system warrantee that most freezers have. If it does, and it is under 5 years, then call Frigidaire to come out to check it out for free. If it is out of warrantee you will need to live with it or replace the freezer, since a freon sealed system repair is very high. Good Luck, Appliance Specialists
Feb 04, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
