Question about Nordic Track NordicTrack T5 zi Treadmill
The console beeps and won't start - Nordic Track NordicTrack T5 zi Treadmill
It turns on and comes onto a report problem so i send it but sometimes a report problem doesn't come up nether the less either way it starts for about 7 seconds then just freezes won't let me move...
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Sep 15, 2011 | Sony Playstation 3 (PS3) Console
My treadmill will light up an make a beeping nose when a button is pushed. The treadmill is pluged up and the red cord magnet is on when the buttons are pushed. However it just does the same beep for...
If the screen is lit and the screen shows that the belt is moving then it’s the motor controller. If the screen does not show that the belt is moving then it’s the console.
Oct 20, 2017 | Horizon Fitness T82 Treadmill
Try to put in disc and it clicks and the disc won't go in.
Hopefully this will help solve your problem:
1. Press and hold down the power button located at the front of the PS3 console, until you hear a first beep, then eventually a second – before the console shuts down, then let go of the button;
2. Now press and hold the button again until you hear a first beep, then a second beep then eventually a quick double-beep, then let go of the button;
3. The TV screen should now display a six option menu, where you can select what’s required, i.e. `Restart System`, `Restore System` etc. `Reset System` should only be used after other attempts with the other options, as your game saved data may be lost. If you play Modern Warfare 2 online, then this won’t be affected as your data is saved on the Sony Server.
4. During any of the above actions, your best having your handset controller connected to the PS3 via the USB cord, which includes pressing the `P` button when required (located between `Start` and `Select`).
These actions should help solve `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Don’t hesitate to contact Sony UK if required, who are very helpful. Their UK number is: 0844 7360595
Good Luck!
Jul 04, 2010 | Sony Playstation 3 (PS3) Console
Every time my friend trys to start home it gos to the loading screen then freezes his system and restarts its self with the 3 beeps. It used to work fine but it only started recently
Good Luck!
Jun 30, 2010 | Sony Playstation Home
It says your hard disc is corrupt
These actions should help solve `Hard Disk Corrupt`, `freeze` problems and others such as update errors etc – which restrict you starting up or playing your console.
Good Luck!
Ps3 will not stay on
Good Luck!
How to solve the 80022D11 error for Ps3 without losing data? For the Trophy collection
Good Luck!
Jul 03, 2010 | Sony Playstation 3 (PS3) Console
My PS2 won't read any of my games when I try to play them. What can I do to effectively stop this problem without having to spend money on it?
Hopefully this will help solve your problem (may be the same for a PS2):
Good Luck!
Jul 03, 2010 | Sony PlayStation 2 Slimline Console
Press power buton and green light stay on for 2 sec and them red came again {dont stay on]
Good Luck!
Jul 03, 2010 | Sony PlayStation 2 (PS2) Console
Player won`t read
turn console onto standby and leave a min
then hold button in till it beeps 3 times and release
then do this again it will beep 3 times last one being double quick beep
a menu should appear
click on the one that says files this will restore your lens reader
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Nordic Track NordicTrack T5 zi Treadmill Logo
90 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
