Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
Brother mfc 7860dw prints blank page - Brother MFC 490cw Color Inkjet Multi-Function Printer
ryeisenman
  • 9 Answers
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Posted on Nov 21, 2009
  • 41 Answers
SOURCE: brother mfc-490cw won't print. sounds like it's
Does the Brother have a print utility, verifying cartridge levels?
You said you printed 40 pages?
Was there a lot of coverage per page?
You know that ALL printers only ship with STARTER cartridges, might want to check that first.
Does it not print black or color also?
Posted on Dec 01, 2009
  • 159 Answers
SOURCE: Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Posted on Jan 07, 2010
  • 10 Answers
SOURCE: prints only blank pages
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Posted on Feb 03, 2010
SOURCE: Brother MFC 7840 W printing blank pages no text or images
Had the same thing happen. Unplugged the power on the printer and plugged it back in. No problems now.
Posted on Feb 07, 2010
Printer not connected, how do I re install
Hello
If you go to the page given below, you can identify your operatign system, and click Search
Downloads MFC 7860DW Others Brother
This will take you to a page from which you can choose your needs for drivers, manuals, software etc and they will mainly be self-extracting .exe files, which when extracted may start automatically to install the relevant programme, or you may need to navigate to the folder to which the files were extracted and double click on a file like setup.exe.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 18, 2014 | Brother MFC-7860DW Laser All-In-One
Why do printouts have increasingly larger blank margins?
Go to the printer's settings menu and look for an option to "Restore Default Settings" or similar words.
Jul 30, 2014 | Brother MFC 7860DW - Multifunction fax /...
Says manual feed. Load paper
There is a manual fee slot just above the paper tray. Sounds like the manual feed slot isn't closed all the way. Here's a link to support for your machine: MFC 7860DW Others Brother Solutions Center Note there is a firmware update available.
Jun 19, 2014 | Brother MFC 7860DW - Multifunction fax /...
I installed a new cartridge in Brother MFC-7860DW after the old one was getting light. It's very new but the message "Replace Drum" is on and the printer won't print. Drum counter shows 12,022 pages. I...
You must reset the drum counter in order to print again. Here is the method http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hl2280dw_us&faqid=faq00002837_000#instruction
Jan 07, 2018 | Brother MFC-9840CDW Laser Printer
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
181 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
