Question about Kitchen Ranges
Viking range hood dimmer switch
We have a Viking range hood model number VCWH3048SS. It has two PAR20 light sockets with a dimmer switch which we use halogen bulbs in the hood. We want to start using dimmable PAR20 LED bulbs. Philips lighting says that for their dimm-able PAR20 LED bulbs we need to install a "Leading Edge Dimmer" so that the LED's will not flicker. Anyone know where I could obtain an LED dimmer for this range hood? Viking tells me that that their new range hoods are shipped with the LED dimmer (they still make the same model), but so far I have not been able to get a part number for this dimmer from them.
    Top Expert:
  • Kitchen Ranges Master
  • 75,822 Answers
Sorry we have no part locating services here at this website.
Posted on Apr 17, 2017
  • 139 Answers
SOURCE: Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Posted on Jan 27, 2008
zeusfaber
  • 247 Answers
If you're getting 120V at the lampholders, yet it's not lighting lamps that still work perfectly well in other fittings, two possibilitiesspring to mind.
One is that the cap on the bulbs isn't quite compatible with the fitting. Assuming they're some variant of Edison Screw, make sure that the centre terminal in the lampholder is sticking out far enough to touch the terminal on the bulb. Also check whether the lampholder achieves it's outer connection just with a small tab, rather than with the whole of the threaded ring. If so, make sure that this is going to touch the appropriate part of the bulb.
The other possibility is that you've got a high resistance connection somewhere - not enough of an open circuit to drop the 120 V when feeding the Megohm load presented by a meter, but more than enough to kill the supply when you have a lamp load. Only way to chase this is to use the meter on ohms range to bell out all the wiring between the lampholders and bits of the system which do work properly.
A.
Posted on Apr 05, 2008
SOURCE: Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Posted on Oct 24, 2008
  • 203 Answers
SOURCE: baumatic cooker hood lights not working
take the bulb out and bring it with you to store and see if you can find one the same . DIY stores have tons of types.Joe
Posted on Nov 22, 2008
  • 6 Answers
SOURCE: viking hood light went out . new bulbs . did not fix it
the dimmer switch/thermostat is most likely bad. resistor inside is burned.p/n pe050033  you can change it yourself with a little mechanical aptitude.
Posted on Feb 25, 2009
Viking hood Lights out
There is a short inside, you need to check wirings to locate the short.
Apr 05, 2008 | Viking VWH3048 Kitchen Hood
The lights on our hood no longer work after replacing them with the exact same type of bulbs. They were replaced because there was a large popping sound and a flash that came from the unit. The dimmer...
the triac on the dimmer control board is defective,you will need to access the board area inside the unit and replace the electronic control board,if your good with a soldering iron and multi-meter and can find a replacement triac you can repair it yourself if the board isn't burned too bad in this area
Feb 27, 2010 | Viking VWH3010 Kitchen Hood
One light blew out and the other stopped working. There is power to the bulb receptacle. Still no light.
not really. i have the same problem. voltage sense electrical probe reads voltage in the sockets, but two new bulbs, tested elsewhere will not light. there are better solutions on this board relating to burned out resistor in dimmer switch.
Sep 21, 2009 | Viking VWH3010 Kitchen Hood
Viking 10 inch hood lights out
It is more than likely the dimmer switch has gone bad and needs to be replaced
Nov 06, 2008 | Viking DTWL4848 Kitchen Hood
Viking hood light went out . new bulbs . did not fix it
Oct 21, 2008 | Viking VWH3048 Kitchen Hood
do the heat lamps work?? or is it the 4 bright lights you are having the problem with??
Part PE050033 no longer exists. It's now two parts: PE050141 for the light and PE050156 for the fan. You must first remove all of the small switches then pull off the front panel to tighten the small nuts that hold the new units in place.
Dec 09, 2007 | Viking VWH3048 Kitchen Hood
Vicking VIDV500 Kitchen Hood
steve...first, is the light working? If not, you may not have power. If so, turn off all power to the unit at the breaker. Remove the filter and see if the blower turns easily by hand. Yes...switch could be bad...no...motor bad.
Open up unit and using test light from the hardware store and motor plug disconnected...turn on fan and probe the motor feed wire for power. It may be the switch that's bad. This should tell you.
Dec 01, 2007 | Viking VEDV900 Kitchen Hood
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
